Results 1 to 7 of 7
May 31st, 2004 02:11 AM #1
Is there a cig. Lighter base that is not less than 20amps? When I checked out car stores they usually have the standard which is 15amps or less. I busted 2 cig. lighter bases just this year because of my water heater (coffee addict ). I hope someone could refer to me a place where I could find these. Thanks!
BANNED BANNED BANNED
- 3,790
June 1st, 2004 03:39 PM #2wala yatang ganyan...its just 20 amp rating. You will have to make your own 20 amp plug, with wires and fuse capable of handling the load of your water heater....baka sunugin mo yung oto mo dahil sa pagiging coffee addict mo.
June 1st, 2004 04:00 PM #3
I see. well, we've been using the water heater on other cars for years already. It was only on my strada that this problem came up. Oh well, I guess I'll just leave out the water heater. I thought there would be 20 amp cig bases here in the philippines.
- 3,790
June 1st, 2004 04:36 PM #4why don't you just tap a new 20 Amp line direct from the battery terminal (equip mo with fuse) and then wire it up a relay switch to a new 20 Amp 12V power plug - you can replace the plugs of your water heater and use the typical 2 prong plug and socket assembly na pang bahay (rated 30 Amp and 220V pa).
Viola you have your new socket just for your water heater.
- Nov 2003
- 190
June 3rd, 2004 06:57 PM #5O di kaya gumamit ka na lang ng thermos? I don't think it's worth it to keep changing cigarette lighter base.
June 4th, 2004 12:15 PM #6
rewire mo na lang lighter wirings mo with 30 amp fuse and proper wire thickness....
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
