Page 74 of 75 FirstFirst ... 2464707172737475 LastLast
Results 731 to 740 of 747
    Jul 2014
    #731
    Yun nga problema ko.. naaawa at out of respect na din sa kasalubong ko. irritating na din kasing palagi kang pina-flash ng kasalubong. So eager to change my HL already.
    #732
    Natry mo na ba iblock yung portion ng lens para mawala yung upper step sa left at maging straight ang cutoff?
    Temporary solution lang habang naghahanap ka ng retrofitter
    Posted via Tsikot Mobile App
    Jul 2014
    #733
    Quote Originally Posted by shok View Post
    Hindi ko pa na-try yan sir. I'm supposed to go that route hindi ko lang alam kung saan dun ang cutoff shield.
    By lens, you mean yung headlight bowl (reflector) — nasa part ba ng reflector yung nag-produce ng cutoff?
    #734
    Quote Originally Posted by Flynn View Post
    By lens, you mean yung headlight bowl (reflector) nasa part ba ng reflector yung nag-produce ng cutoff?
    Sa reflector usually yung nagproproduce ng cutoff if the lens is clear. Ideally that is where you should block, but you need to open the HL so don't go there muna.
    You can experiment by blocking portions of the HL lens while the light is on and facing a wall around 20ft away.
    Check kung saang area ng HL lens ang kailangan mo iblock to remove the upper step that shines on the opposite lane.
    Not sure though if this will work 100% but it's worth a try for a temporary solution.
    Aug 2009
    #735
    Ask ko lang kung comparable or mas maganda pa ang output ng MH1 or Q5 ni pao vs sa OEM ng Montero GLS SE and kung worth-it ba yung price difference between the two mentioned lenses. First time ko kasi naka-drive ng HID-equipped as factory stock being the montero and gustong-gusto ko yung output niya. Sakto kasi para sa paningin ko yung output nung monty kaya naisipan kong magpakabit. BTW, this is for an Innova. TIA!
    #736
    Quote Originally Posted by Sleepcare View Post
    Q5 na kung bolt on.
    Aug 2009
    #737
    Q5 na kung bolt on.
    Ok copy sir. Thanks for your input.
    Q5 na kung bolt on.
    Feb 2015
    #738
    Sino pala pwede mag retrofit pag may kit na ko?
    Apr 2015
    #739
    May naka try na ba kay Xenon Concepts? Any feedbacks po? I'm planning to upgrade my stock reflector headlamps. Thanks!
    Jan 2012
    #740
    good evening mga sir, saan ba pwede bumili ng bi xenon mini h1 projectors.
    balak ko kasi mag diy retrofit. pangit kasi buga ng PNP hid ko. thanks
Bolt-on bi-xenon projectors
