Results 621 to 630 of 747
December 22nd, 2013 09:58 AM #621
Yung short tail ba ay hindi uubra sa H4 mounting? May enough thread ba sya to mount the bulb holder? May nakikita din ako na iba yung tail nya parang square. Ito ba yung hindi bolt on type at replica talaga ng Q5?
Sent from my GT-N7100 using Tsikot Forums Mobile App mobile app
December 22nd, 2013 01:14 PM #622
basically yung lumens ng light output eh determined by the ballast... 35 watts is the regular wattage... 55 watts produces more amperage and in a way boost the existing bulbs output... 55 watts generate more heat and shortens bulb life to a certain degree.
35watt (4300K bulb) + 35watt ballast= 3400 lumens
35watt (4300K bulb) + 55watt ballast= 5000 lumens
there are bulbs though with thicker electrodes and stronger glass that can retain color and lifespan even with 55 watt ballast that drive them up...
December 23rd, 2013 02:26 AM #623
Ahhh ... thanks sir ...
Sent from my GT-I9300 using Tsikot Forums Mobile App mobile app
December 23rd, 2013 09:51 AM #624
Sir Ginnova, I checked the clearance of the HL with respect to the bezel and it is only exactly 80mm. The diameter of the lens holder of a bare Q5 is also 80mm.
Looks like I'm out of luck with projectors using 3" lenses unless I do major trimmings on the shroud and/or reflector bowl or wala ng shroud and just cover the opening between the lens and bowl.
I guess I'll just have to settle with the MMH1 6.0 for bolt on installation.
December 23rd, 2013 10:02 AM #625
December 23rd, 2013 11:53 AM #626
Sale nung binili ko sya last year, i guess stocks ran out din pala. If one tims mo lang gamitin, try mo yung jafake sa quiapo . I think pede na yun wag lang for professional use..
* sir ginova Whats the difference between MH1 vs. FXR or Q5 3.0 na projector? Aside sa mas maliit
Sent from my GT-I9300 using Tsikot Forums Mobile App mobile appLast edited by blue_gambit; December 23rd, 2013 at 11:56 AM.
December 27th, 2013 10:11 PM #628
some of the guys at HID planet prefer MD2S instead of MH1 for bolt on projectors. MH1 usually uses after market bulbs while MD2S uses mostly OEM bulbs. some bad reviews of the MH1 are inconsistent hotspots but we cant expect an excellent output from an entry level setup(MD2S/MH1) naman. and either way you can't go wrong sa dalawang yan basta proper lang ang pag install and city driving lang naman.
- Jan 2011
- 34
December 27th, 2013 11:55 PM #629Sir shok, I also own a toyota corolla lovelife and was inspired by this bolt on thread to perform a diy on my car headlights. At first medyo nag aalangan ako with Q5 dahil sa size ng headlight kaso maganda kasi feedback kaya itinuloy ko pa din. I sourced my projectors directly from china and bought a pair of 3 inch Q5 projectors and pair of 2.5 inch ultimate mini projectors pang back up in case na di ko talaga ma fit yun Q5, ibenta ko nalang yun di ko magagamit. I choosed the ultimate mini as back up kasi andami mini projectors sa china and yun ang model na mas maganda ang output compared to the regular na mini kasi ang daming copy nyan sa china and mahirap malaman ano yun equivalent ng latest morimoto model unless sa TRS ka bibili.
When the projectors arrived, I was able to succesfully fit the Q5 on my corolla's headlight and was satisfied with its output specially compairing it with my previous halogen na RHD pa ang output hehehe.
Here is my first diy output.
December 28th, 2013 08:51 PM #630
T badge premium... imagine a 1.4M car without cruise control... Sent from my Nokia 3210 using...
All New Toyota Corolla Cross
