Results 581 to 590 of 747
- Dec 2002
- 2,335
July 22nd, 2013 01:09 PM #581there are copies and copies of copiesbuy from someone who will test the projectors for you to make sure yung position nung bulbs are optically positioned right, shields are positioned correctly with no problems switching from LO to HI and the spacing of the glass optics from the projector body is correct. Dont buy from resellers who will not do this for you. Sayang lang pera mo if you get a projector with problems
- Jul 2013
- 22
July 25th, 2013 12:16 AM #583There is a Philips D2S na Morimoto bixenon, had it in my civic SIR for 4 years na, and yes it is very bright, talo niya yung binili ko sa The Retrofit source na morimotos with their own H1 bulbs.
- Jul 2013
- 22
July 25th, 2013 12:20 AM #584i have extra philips d2S bulbs, mahal nga lang po ang mga ito, then also a d2s to regular hid adapter harness. extra items na di ko na ginamit because car ko ngaun has oem projectors. but the SIR still going strong pa mini bixenons
July 25th, 2013 12:24 AM #585
Philips h1 bulb costs 10k a pair. Papalitan ko na lang tint ko sa windshield to a lighter one, cost efficient pa.
#Retzing
- Jul 2013
- 22
July 25th, 2013 12:39 AM #586
- Dec 2002
- 2,335
July 25th, 2013 12:44 AM #587
July 25th, 2013 05:03 AM #588
Curiously, i've read different reactions concerning Mori Mini H1 vs the Mini D2S showing that many favors the width and light intensity of the MH1 over the MD2S. I think it's more of the projector design than the bulb used.
But if it works for you, then kudos to you sir.
July 25th, 2013 09:40 AM #589
- Jul 2013
- 22
July 25th, 2013 11:43 AM #590
I have both, years back when i was car crazed and bought a lot of these retrofits, even queried gary about it but i have to back out since I am from far his area. ordered from retrofit source, bought from ali all i can experiment on. the best mini bixenon is still the d2s bulb and morimoto projectors (except of course the FXR) and this is based on personal experience. However I have not tried the new q5 or newer designs found in ali
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
