Results 481 to 490 of 747
August 26th, 2012 10:19 PM #481
i have used all 3 of them. here's my ranking. q5 > mh1 > g5. q5 use d2s so you have upgrade options in the future. it's also the biggest among the 3. lens is 3inches . the q5 also has a different bowl designed for farther light throw unlike the mh1 and g5. pls note these are aftermarket projectors ( china ). Q5 would be a good upgrade if you plan to use 55Watts since the bigger bowl can handle the higher power safely. what is notice with q5 though is more light is reserved for high beam. if you're comparing it with an OEM projector like the TL ( still considered bi-xenon king by most ) , q5 is still miles away though.
August 27th, 2012 10:43 AM #482
i'll try to post pic nang output q5... very happy, finally nakuha ko na din yung perfect cut-off, kagabi lang kasi ako nagka time uli mag adjust , gaya nang mga posting sa HIDPLANET. hehehe...
http://i46.tinypic.com/n4insz.png
http://www.theretrofitsource.com/ima...mh1mazda6l.jpg
August 29th, 2012 11:53 PM #483
Low beam:
High beam:
With all my lights including foglamps and overhead lamps switched on:
August 30th, 2012 08:52 PM #484
finally nakakuha na ako pic output nang 3 inch KOITO Q5, care of sir ginnova
low beam only!!! hehehe
morimoto 50watt ballast
Morimoto D2S 50watt 5000k bulbs( nakakasawa din kasi minsan pag Philips 85122+ eh)
Miles from the G5 china,
Far from The Morimoto projectors...
but cheaper and comparable to FXR! without the destroying your OEM housing dahil bolt-on pa din...
malapad and malayo yung buga plus uniform yung width... (sharp CUT-off too)!
your money will be well spent with a headlight upgrade like this...
August 31st, 2012 06:38 AM #486
Nice one Miko although you may need to rotate the projectors a bit counter-clockwise. Phillips 85122+ powered with 55Watts ballast is also too yellow for my taste as well. Still have 1 set ( anyone interested , pm me. i'm selling it for a bargain ). CBI for the win.
I miss my projectors. Hirap mag-drive sa gabi using stock halogen bulb.
August 31st, 2012 07:59 AM #487
Pm nyo sir blu_gambit si sir ginnova,around 7 o 8k ata...
Sir ginnova, nakaka OC talaga yung pag adjust nang rotation para super perfect yung cut off, kaso hastle buksan ulit headlight o tanggalin hehehe...
Maganda i-DIY mga ganitong project...
August 31st, 2012 08:45 PM #489
sir ginnova, ito ang kasama nang bolt-on projectors ko sa eve namin...
ito lighting setup ko.. hehehe
September 11th, 2012 04:05 PM #490
help, minsan ayaw umilaw nung headlight ko. minsan isang side lang. kelangan papatayin ko ulit para sumindi sila pareho. ano kaya problem non? sa bulb na? ballast?
thanks
Suzuki JIMNY [merged threads]
