Results 461 to 470 of 747
July 31st, 2012 08:17 AM #461
ok din naman bolt on na gaya gen5.. pero there's a big difference sa light output at performance... dati po kasi gen5 ako....
pag nag 3 inch lens ka na projector tapos lagyan mo nang philips85122+ na bulb napaka layo na ng difference...
pero for starters pwede na tlaga g5... dame ko na din nabili from sir paolo of sulit....
hahaha... good seller yang si paolo...
July 31st, 2012 10:22 AM #462
July 31st, 2012 05:47 PM #463
yup. balak ko nga mag morimoto dapat kaso mas mahal na siya. ayoko naman gumastos na ng ganon. hehehe. maliwanag na yung gen5 para sa akin kaya ok na. hehehe. sa susunod na lang siguro. sa ngayon, more than enough na yung gen5. hehehe
- Oct 2010
- 19
August 1st, 2012 12:50 AM #464
August 1st, 2012 08:29 AM #465
hindi po... ang koito projectors lang ang kinuha ko keh sir ginnova.... kasama is shroud lang po...
the philips bulb i got it from sulit pati yung ballast... kaya nakamura ako...
August 3rd, 2012 04:14 PM #466
yung akin parang mahina ata yung output ng gen5 ko. hindi ganito....
I'll try to post pic pag may chance. hindi kaya dahil madalas pa basa kalsada kaya hindi ko lang mapansin yung liwanag niya talaga? saka yung hotspot niya parang ang lapit sa bumper. parang ang layo nung akin. parang ang hina ng ilaw....
August 3rd, 2012 10:48 PM #467
post ko pic sometime this week pag wala na masyado ulan...
difference lang is malayo at malapad ang bato koito projectors...
depende ata sa camera settings eh...
- Jul 2008
- 485
August 14th, 2012 12:44 PM #468sir i also got projectors from pao. the heat spot is centered on the border of the cut-off so if mataas ang sipat ng projectors mo, malayo at mataas din ang hot spot. its not totally 100% plug and play kasi you still need to adjust your headlight (up/down-sideways) to get the perfect aim of the projectors. remember that the headlight was aimed for the original halogens it was isntalled with.
better to adjust it first by aiming it at a wall, then try it on the road, then make the final adjustments. it took me several hit and miss adjustments to perfect it. if you do it against the wall, first at low then at high, you will see the hot spot (right at the edge of the cut off). malakas talaga buga ng 55 watts pero again, you have to perfect the adjustment para sakto sa preference mo (whether the hot spot is near the bumper or farthest possible na hindi naman nakaka silaw sa kasalubong).
August 14th, 2012 03:56 PM #469
nice. thanks. mukhang dahil basa nga lang yung kalsada kaya feeling ko mahina. hehehe. nung hindi umuulan ok naman siya. problem ko ngayon yung width niya sa kanan side. hindi maayos tulad nung sa kaliwa. ayusin ko pa alignment kasi hindi ko pa maayos yung horizontal alignment.
pansin ko lang nung isang beses parang may play yung ilaw? kita ko sa harapan ko na kumakalog yung ilaw kapag naka idle sa traffic yung sa right side. pero after a while nawala din naman...
- Jul 2008
- 485
August 16th, 2012 10:38 AM #470another thing i discovered sir, since china made yung projectors and bulbs, hindi maganda fit ng bulbs sa housing, you will notice maluwag sya kasi may space yung butas against the width of the bulb base (as compared siguro sa perfect fit ng oem prjectors or morimoto) kaya you also have to find try and move the bulb (slightly up or down) and see the best focus on the wall. yung sa akin, i needed to put a small metal screw under the bulb base against the projector opening kaya medyo naka "yuko" ng konti yung bulb at para snug fit sya sa projector. did this for borh sides. better focus of the light and di na sya umaalog.
doubledouble.
2024 Manila International Auto Show APRIL 4-7,...
