Results 271 to 280 of 747
May 8th, 2011 05:31 AM #271
If you are ordering from The Retrofit Source you can use this coupon code "TacomaWorld" without the quotes. You'll get additional 25% off their complete kit.
May 8th, 2011 12:26 PM #272
the adjustable ballast are actually better than the standard ballast. . dimming is done through variable resistor only. you can lower the output at around 45 watts. less stress on the bulbs as well as the ballast itself.
- Dec 2002
- 2,335
May 8th, 2011 10:33 PM #273It would be interesting to find out how long the adjustable ballasts will last.
May 16th, 2011 03:17 PM #276
sir ginnova, nakapag order na ako sa xenon-man. any recommendation san ok magpakabit?
- Jul 2008
- 485
May 17th, 2011 08:59 AM #277hi to all. i have a bolt-on 35W bi-xenon projectors installed in my xtrail. i want to increase the intensity of the output. can i do this by replacing the ballasts to 50W? will the existing bulbs (D2h) perform well with the upgrade in ballasts? thanks
May 17th, 2011 10:14 AM #278
- Jul 2008
- 485
May 17th, 2011 11:41 AM #279i believe it is gen 3 or 5.. according to the seller, pwede ko upgrade to 50watts yung balalsts to increase the intensity. saan pwede makabiuli ng 50watts ballasts mga sir?
May 17th, 2011 12:34 PM #280
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
