Results 731 to 740 of 747
- Jul 2014
- 20
July 30th, 2014 01:56 PM #731Yun nga problema ko.. naaawa at out of respect na din sa kasalubong ko. irritating na din kasing palagi kang pina-flash ng kasalubong. So eager to change my HL already.
July 30th, 2014 04:17 PM #732
Natry mo na ba iblock yung portion ng lens para mawala yung upper step sa left at maging straight ang cutoff?
Temporary solution lang habang naghahanap ka ng retrofitter
Posted via Tsikot Mobile App
- Jul 2014
- 20
July 31st, 2014 06:57 AM #733
July 31st, 2014 10:39 AM #734
Sa reflector usually yung nagproproduce ng cutoff if the lens is clear. Ideally that is where you should block, but you need to open the HL so don't go there muna.
You can experiment by blocking portions of the HL lens while the light is on and facing a wall around 20ft away.
Check kung saang area ng HL lens ang kailangan mo iblock to remove the upper step that shines on the opposite lane.
Not sure though if this will work 100% but it's worth a try for a temporary solution.
February 19th, 2015 10:14 PM #735
Ask ko lang kung comparable or mas maganda pa ang output ng MH1 or Q5 ni pao vs sa OEM ng Montero GLS SE and kung worth-it ba yung price difference between the two mentioned lenses. First time ko kasi naka-drive ng HID-equipped as factory stock being the montero and gustong-gusto ko yung output niya. Sakto kasi para sa paningin ko yung output nung monty kaya naisipan kong magpakabit. BTW, this is for an Innova. TIA!
February 23rd, 2015 10:55 PM #737
- Feb 2015
- 2
February 25th, 2015 02:38 PM #738Sino pala pwede mag retrofit pag may kit na ko?
- Apr 2015
- 1
May 21st, 2015 03:49 PM #739May naka try na ba kay Xenon Concepts? Any feedbacks po? I'm planning to upgrade my stock reflector headlamps. Thanks!
- Jan 2012
- 2
July 23rd, 2015 08:58 PM #740good evening mga sir, saan ba pwede bumili ng bi xenon mini h1 projectors.
balak ko kasi mag diy retrofit. pangit kasi buga ng PNP hid ko. thanks
as an aside, in the olden days, anyone who does not move 'ala luksa during Holy Week, especially...
Traffic!
