Results 551 to 560 of 747
July 18th, 2013 04:07 AM #551
Problema lang, "kulang ng buga" is vague. Kung gusto mo, face a wall... turn your lights on.. and picture it. That'll give people a better overview of the problem. G3 bi-xenon projectors are actually quite good alternatives to OEM bi-xenon ones.
Going from 55W from 35W will obviously be "better" in terms of light output. I believe it'll be around +20% improvement in lumens output although YMMV. The leap from the usual halogens to 35W 4300K HIDs is like +300% I believe. For most, 35W HID in retrofitted projectors is GOOD ENOUGH..
In comparing a 35W 6000K to a 35W 4300K, the 35W 4300K has more light/lumens output. This is why OEM manufacturers use it as their standard Kelvin temperature... it's the most optimal.
Personally, I've never been a fan of 4300K, I find them too yellowish. A good compromise would be 5000K.
P.S. I know what a 4300K, 5000K, and 6300K look like.. because I have all three. Headlights, DRLs, and park lights ko sila in that order
July 18th, 2013 09:20 AM #553
do you have tint in your windshield sir vinz_p?
- Dec 2002
- 2,335
July 18th, 2013 10:06 AM #554
- Jul 2013
- 6
July 18th, 2013 08:07 PM #555Sir gary, ang ibig nyo po bang sabihin palitan ko nlng ung g3 ko. Since na fd nmn po ung car ko baka mag quad set up nlng po ako. Ok na po ba ung morimoto mini? Sayang nmn po kac ung G3 kung hindi ko gagamitin. Wala na po bang pag asa kung HID lng ang papalitan ko? Thanks.
- Jul 2013
- 6
July 18th, 2013 08:20 PM #557
1. Remove tint or switch to less dark ones
2. Go 4300K
Ang bilis bilis lang pinapahirapan niyo pa sarili niyo. I will always try the most cost-effective solution first before going up the cost ranks.
- Jul 2013
- 6
July 18th, 2013 08:22 PM #558
July 18th, 2013 11:56 PM #559
July 19th, 2013 09:54 AM #560
mas ok walang tint para lahat light output eh kita ng eyes... good and balance compromise would be hangang medium tint, pag nag super dark or dark talagang mahirap makakita kahit anung headlight pa...
G3 output is really not good... baka mas ok pa na mag philips halogen bulbs ka na lang... before kasi G5 gamit ko and its really crappy..
So Q5 projectors kinabit ko.. ayun ok ang output and cut-off pati light distribution ay very good and hindi ganun ka mahal...
2 set ng bulbs meron ako all powered at 50w by ballasts, 4300k(philips 85122+) and 5000k (morimoto)... trust me, mas ok ang 4300k!!!! mas maliwanag, mas maganda light refraction on all environments, at hindi nakaka sakit sa mata...
the 5000k bulb is more of pang porma para sakin dahil pure white.... pero bakit unahin porma against safety and quality...
go for quality projectors and correct kelvin rating (4300k)/ do not put heavy tints... and masaya and safe mag drive sa gabi
Monk-owned R53
