Results 501 to 510 of 747
- Oct 2012
- 24
October 31st, 2012 12:40 AM #501Good day mga Sir,newbie lang po ako sa forum at gusto ko lang po sanang humingi ng tulong.Nalilito po kasi ako in between Bi Xenon morimoto H1 at D2s.Sa mga nabasa ko kasi sa forum na ito,sinasabi nila na mas maganda ang D2s since maraming bulb ang pwede rito kesa H1 HID light lang ang pwede.Gusto ko sanang itanong kung pupuwede ito (D2s)sa headlight ng starex na 2000 model.If I remember it right yung lowbeam ng sasakyan ko ay h7 yung gamit na halogen.Any help mga Master,I will appreciate it,thanks.
October 31st, 2012 05:50 PM #502
sir i suggest that if your planning on using morimoto H1 or morimoto D2s na dagdag ka na lang onti pang budget and go for Q5 projectors or FXR's....
para isang gawaan na lang at the same time mas maganda at ok ang beam pattern....
like what others have already mentioned entry level ang morimoto...
pero according to my experience, mas precise ang construction ng bulbs that uses the D2S specs... if you want to go the morimoto ok ang D2S basta philips ang bulb na lalagay mo or morimoto bulbs din...
- Oct 2012
- 24
November 2nd, 2012 03:50 AM #503Thanks Sir Miko sa advice.I was thinking that also kaya nga lang sa nakita kong picture ng FX R's siguro kailangan kong mag laki ng butas ng reflector dahil iba yung size ng pinakapuwet ng FX R.Tama kaya ako Sir sa hinala ko?
November 2nd, 2012 08:28 AM #504
First thing to consider is the budget. How much are you willing to spend. Choosing a good projector ( preferably an OEM ) would be the 1st priority. 2nd would be the bulb and ballast coming at 3rd.
- - - Updated - - -
November 2nd, 2012 08:44 AM #505
Tamaka diyan sir, if projectors na OEM like FXR's, babawas ka talaga sa likod ng reflectors kasi malaki siya.. Then you need to either glue it or put a way to hold the projectors inside the reflector housing.... Kumbaga wala ng balikan kasi modify mo na housing ng stock reflector housing. Pero sulit naman yan. You wont want to come back to halogen after mo mag retrofit... Tama si sir ginnova, budget ang first to consider,, kasi if you have the budget this is the setup
Fxr- projectors
Philips 85122+ - bulbs
Morimoto/matsushita/denso OEM's - ballast
Medyo pricey nga lang pero itsworth every penny...
Kung mag Q5 ka na projectors sir, mas maganda siya sa morimoto pero hindi mo need na butasin reflector mo....
- Oct 2012
- 24
November 2nd, 2012 10:09 PM #506Thanks again Sir Miko and Ginnova,alam ko na kayo ang mga expert pagdating dito.Tama kayo,that depends on how much are you going to spend.The better,the more pricy.Naisip ko rin yung Q5 projector pero siguro ipon muna then decide,Thanks.
- Jul 2008
- 485
November 5th, 2012 10:03 AM #507
November 5th, 2012 11:29 AM #508
si sir ginnova baka meron pa siya sir... pero ikaw gagawa niyan... or pwede mo din pagawa sa labas... Pm mo na lang si sir ginnova....
meron din nag ooffer sa net... search ka sa sulit...
http://www.**************/index.php/...sition,1-11,11
type mo na lang sa sulit "magtatertots " nagpaparating sila at install projectors depende sa budget mo...
- Jun 2007
- 32
November 28th, 2012 09:40 AM #509good day po sa lahat newbie ako regarding sa projector, ask ko lang po anybody buy from TRS.
November 28th, 2012 09:52 PM #510
Bought 3 sets of Philips 85122+ bulbs and a pair of TL projectors before.
