Results 451 to 460 of 747
January 8th, 2012 11:16 AM #451
some output shots of the 3in D2S bolt-on projector. very nice cut-off beam. colorful,sharp,straight and wide.
January 9th, 2012 10:33 AM #452
patulong po mga sirs. pag naka low beam po yung HID projector ko nagdadrop po yung RPM ko na para bang naka on yung aircon.
TIA mga sir!
January 9th, 2012 12:17 PM #453
ano bang hid ang nakakabit sa kotse mo ngayon. may wiring harness na nakakabit or your just using stock headlight wiring to power the ballast
July 25th, 2012 10:35 PM #454
update lang natin tong tread na to... sir ginnova ito pics nung nainstall na bolt on d2s.. DIY lang din pero gumamit na ako maayos na bulb and ballast
projectors: bought from sir ginnova, 3 inch koito d2s ata name nito
( superb output and distribution nang light)
bulb: Philips 85122+
ballast: morimoto d2s 50watts
shroud: apollo ata name ng shroud
harness: provided by sir paolo(pdm88 of sulit)
wiring loom
2 morimoto relays
fuse block modification
July 26th, 2012 08:00 AM #456
nag DIY lang ako.. pina heat gun ko sa labas tapos ako na nag lagay projectors at align... tapos ako source out parts pati lagay harness DIY na din, para makatipid, hehe sulit,
lakas output grabe, kaka enjoy mag retrofit ng bolt on.. hehe..
July 26th, 2012 03:08 PM #457
July 26th, 2012 09:49 PM #458
July 27th, 2012 03:53 AM #459
i got the Philips 85122+ from sulit. he was a member of team celerio and only used the bulb for 3 months since he will be selling his car... i got the 85122+ for just 1k!!! and he sold his morimoto 50w ballast for 2k only!!!
right now meh extra pair na morimoto 50w 5000k na bulb ako, yung philips 85122+ pag sa 50w na ballast mas ok sa mata yung pagka yellow, yung 5000k na bulb parang masyado maputi...
total cost ko d2
projectors:7500 ata from sir ginnova
bulb: 1000 for philips85122+
ballast: 2000 for morimoto-five 50w
harness h4: 500
2 pieces morimoto relay: 500
heat gun sa banawe: 400
merienda koh: 200(ahahaha)
total 11,900 pesos....
July 30th, 2012 05:05 PM #460
kakapakabit ko lang din ng bolt-on projectors. kay paolo ng sulit ako kumuha. 7300 all in
gen5 projectors
4300k bulb
55 watts slim ballast
may free park light pa. hehehe
sulit na sulit. tagal ko pinag-isipan to. hahaha.
Suzuki JIMNY [merged threads]
