Results 251 to 260 of 747
- Oct 2009
- 11
April 30th, 2011 07:11 PM #251Should I get the shrouds first before having it done sa kanila? Para isang labor na lang, also thinking of adjusting the shield to get more color on the cutoff
April 30th, 2011 07:31 PM #252
yung shroud is for aesthetics.
original g5 built-in shroud. too small for big headlights
Eto yung may additional apollo shroud.
get the shrouds 1st before you go there. should be mounted before the headlight is sealed. I have an extra apollo shroud. pm if youre interestedLast edited by Ginnova; April 30th, 2011 at 07:55 PM.
April 30th, 2011 07:51 PM #253
- Oct 2009
- 11
May 2nd, 2011 12:03 PM #255
May 2nd, 2011 10:02 PM #256
i contacted xenon-man. H4 bulb lang daw for the g5. is it ok? or kailangan d-series?
May 3rd, 2011 12:09 AM #257
G5 uses their own bulb. But if your order the projector for H4 housing, D2S bulb will fit the projector. The bulb included is a cheap one and will color shift fast and output lumens will drop after a couple of months use.
I also recommend to buy locally for warranty purposes. I'll be cheaper in the long run.
May 3rd, 2011 12:17 AM #258
- Dec 2009
- 3
May 4th, 2011 12:58 AM #259Paulo just installed Bolt On Projectors to my SX8..
panalo.. will post pictures later..
but definitely a satisfied customer...
May 4th, 2011 08:53 AM #260
Thank you!
