Results 21 to 28 of 28
October 19th, 2006 02:26 PM #21
*doc otep
what would you recommend? newbie po ako sa cars. should i change the headlight bulbs? to what? how? sorry wala po talaga ako alam dito hehe
if auxilliary lights/fog lights naman po, what would you suggest?
October 19th, 2006 02:33 PM #22
Cheapest way to upgrade lighting would be through a wiring harness upgrade (Php500.00 ang complete wiring kit sa BLADE, plug and play AFAIK) and use high wattage bulbs.
Hirap ka na ba makakita sa dilim? Kamusta ang vision mo?
October 19th, 2006 02:36 PM #23
Add auxiliary lamps.
Auxiliary lamps allow you to see far, so they are most often used off road or when there are not a lot of people. Fog lamps are used so you can see the immediate front and maybe front-side of the road ahead of you. A good wide band, like Doc Otep said, is best for this. Most of them have H3 bulbs. A standard color bulb is best for all around use, some say a selective amber light is good too (back in the 80's uso ito).
Go to www.danielsternlighting.com and read about the fog lamps section. The reason yellow light is best is because it is the opposite of the blue light spectrum, which causes glare. Ever wonder why HIDs, superwhites, hyperwhites, blue lights, etc cause glare? Blue/violet light has short wavelength, hence it's hard to see compared to red/yellow which have longer wavelengths.
To the author of the thread, whatever car you have, buy the fog light accessory for it from the dealer/banawe and have regular H3's installed. Most important: aim your lights properly. Itapat mo sa pader yung car, turn on the lights (headlights/fogs) and make sure it has an even/flat band of light for the fogs, and the headlights do not point up (a longitudinal wall perpendicular to the wall facing your car is good so you can see if the light is level, pointing up, or pointing down). Just to give an idea of how the fog lights should illuminate the road, look at the attached pic. Also below is a pic of my car with the fogs on. Masmadali makita sa road yung mga naka amber/yellow fogs. Actually red is the most seen in fog, but you wouldn't want a red light in front of the vehicle. So the best is orange, but that's already used in turn signals and other front light markers, so yellow is next in the light spectrum.
October 19th, 2006 03:30 PM #24
October 19th, 2006 03:32 PM #25
Yep, I meant during fog and inclement weather.
The contrast of yellow is easier to see than white. Besides, it is illegal to have forward facing red lamps.
October 19th, 2006 03:32 PM #26
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
