Results 1 to 10 of 11
- Apr 2007
- 19
September 7th, 2007 11:21 PM #1kanina lang before i left for work,i noticed na parang medyo dim un mga lights sa van ko.also noticed na parang mahina yun pag angat ng power window.now when i parked na,i turned the engine off,tried starting it again,ayaw na,kahit redondo wala na.pero i can still turn my radio on tapos nag reset din yun clock.ano po kaya nangyari mga sirs?im still hoping na makuha pa sa tulak sana para umandar and i can bring to a electrician.
September 7th, 2007 11:27 PM #2
things to check
1. battery terminals baka maluwag or madumi na
2. battery water baka kulang na
kung alang problema alternator, pwede mo patulak or kung may jumper cable, di naman titirik yan wag lang magkamali ng bitaw ng clutch...
- Apr 2007
- 19
September 8th, 2007 12:43 AM #3thanks boss for the very quick reply.usually ang diesel aandar kahit dead alternator di ba? sige ill check on the battery tommorrow pag out ko.but as far as i can remember, i checked the battery just 3 days ago and ok pa yun battery water.but ill double check again.will also check the battery terminal.any other advise sirs??
September 8th, 2007 09:49 AM #4
Pag ok naman battery and batterry terminals mo, malamang alternator mo na ang sira. Meaning to say hindi na nag cha-charge ng battery yung alternator mo. Diesel engine right now is tumitirik na din pag naubusan ng battery. Mas magandang bumili ka na lang ng surplus na alternator na original pa ang winding niya kaysa ipa-rewind mo yang alternator mo kung sira man. Mas matibay talaga ang original winding ng mga alternator kaysa sa mga rewind na lang sa auto electrical shop.
September 8th, 2007 11:47 AM #6
first to do when it wont start, pukpok ng konti terminals ng battery. baka maluwag lang.
pag ayaw talaga, jumpstart na yan.
palit na batt kung luma. if still new, check the alternator naman.
September 8th, 2007 09:44 PM #7
Kung ok naman ang connections ng battery, ok naman ang mismong battery, delikado na palitin na ang battery, pero puwede rin na may problem ka sa alternator, di nya na cha-charge ang battery kaya naghihina.
Try mo na ipa charge ang battery, kung possible, ipa-check mo bawat cell ng battery, baka may sira/tama na. Ipa check ang alternator kung nagcha-charge siya ng battery.
- Apr 2007
- 19
September 10th, 2007 12:18 AM #8[SIZE=3]maraming salamat mga bossing!i had it checked by an electrician,we found out that the culprit was a faulty wiring.bali pinalitan yun linya na yun then now ok na sya.however,another problem came up,nagalaw ata yun linya nun aux fan para sa a/c ko.papatignan ko nalang ulit.medyo luma narin kasi van ko,95 na hyundai grace.pero im still looking forward na mapaayos lahat sa kanya.may sentimental value na kasi sakin eh.i think kelangan ko na sya iparewire.malakas pa naman daw alternator ko and battery was purchased last 03/28/07 lng.any recommendation of a good and trusted electrician?tsaka rough estimate po kung magkano aabutin pag paayos ng wiring?[/SIZE]
- May 2007
- 236
September 10th, 2007 03:12 AM #9mura lang ang pa rewiring.kung ako syo eh yung sa me problema lang ang ipaayos mo.[SIZE=3]wag mong ipa rewire lahat.at yung magandang klase na wire ipakabit mo.yung iba kasing electrician ehyung mumurahing wire ang ikinakabit.sasabihin eh malaki wire pero manipis lang yung cable sa loob.ang makapal lang eh yung covering.[/SIZE]
- Jan 2007
- 187
September 10th, 2007 05:30 PM #10try d2h motorworkz sa may e rodriguez. look for danny. sya may ari ng shop. tagal ko na electrician yan. mura singil. magaling pa gumawa. magkakapatid sila na gumagawa dun.
Monk-owned R53
