Results 21 to 29 of 29
July 15th, 2009 02:40 PM #21
advice ko lang. if your car doesn't comes with projector headlight assembly pls pls pls! do not install HID
for better visibility during night or rainy condition change your stock bulb to all weather bulb, philips xtreme power or osram nightbreaker. or better yet remove your tint kung naka tint windshield niyo.
July 15th, 2009 02:59 PM #22
i'll answer your question sir to the best that i can...
1. may adjustments yan sir, baka hindi nyo pa na-eexplore mabuti ang sasakyan ninyo. usually po, eh nasa likod yan ng headlamp assembly mo.
2. use 4300k color temperature. siguro, max na ang 6000k color. bakit hanggang dyan lang, kasi you must be concern din sa visibility mo sa ulan at fog, and sa mga kasalubong mo. 35w or 50w, either na po yan...
sort of advice lang sir, follow sir valskie's advice. tama po ang sinabi niya. kung gusto nyo talaga maglagay ng hid, better have your headlamps retrofitted with projectors. the proper and correct way of using hid is to have your headlamps projectors. if your headlamp assembly does not have projectors, have them retrofitted. be responsible enough po sa paggamit ng hid sir...
- May 2009
- 119
July 15th, 2009 03:34 PM #24sir testament11 thanks for the reply..
hmmm later icheck ko ulit kasi parang as a whole yung lense ng sa sportivo na headlight pati yung lense ng signal and clearance light ay iisa lang na kasama nung sa headlight but I will check it later sir thanks...
lastly meron po ba puwede magshare or nakagawa na ng projectors for sportivo type na headlight pa post naman po ar PM po ninyo ako kung saan bumili kung DIY or if sila magkakabit mga how much ang uubusin...meron na siguro sa casa ngayon kasi yung 2010 na sprotivo eh projector na pero sigurado laglag ako sa upuan ko kapag nalaman ko presyo nun hehehe...
thanks...
July 16th, 2009 12:36 AM #26
*jaz014: save ka nalang ng ilang buwan para hindi ka malaglag. hehe...
mas maganda salpak nalang. retrofit sometimes fail and needs maintenance...
- May 2009
- 119
July 21st, 2009 12:30 PM #27sir xenonoptics thanks sa reply...
anyway ulitin ko lang po yung tanong ko above if kung meron po adjust ang focus ng light ng headlight ng sportivo para po kasi ako wala makita na pihitan...or hindi ko lang po kabisado kasi dati po dun sa small body corolla ko meron 2 screws for both up-down and left-right aiming....
could you suggest HID with 50 watts na may takip na good quality?planning to install one...
thanks and more power...
- Nov 2008
- 136
July 21st, 2009 12:44 PM #28Good day guys!
Mga bro hingi lang ako advise bout sa hid for nissan sentra N16, magkasama kasi yung hi and lo nun eh. anung maaadvise nyo na brand and wattage sana.
Salamat guys! More Power!
July 29th, 2009 02:10 AM #29
hindi pa nalalabas ang fd na ito nagpa sched na sa akin at reserve ng hid. naka xenon optics din yung dati niyang civic. pero nabenta na so nagpakabit lang siya ulit sa bago niyang kotse
share ko lang since you guys are asking what brand to install baka mainterest ko kayo .
as of july 27, 09
installed 3 sets of xenon optics hid on a week old car
35w hid 6000k for the fogs and the high beam
50w hid 6000k for the low beam
Maraming Salamat :)
