Results 81 to 90 of 145
June 18th, 2009 10:28 AM #81
Yan ang problema dito, konti lang ang may konsiderasyon na katulad natin.
I usually don't turn on my highbeams unless I really have to and I make sure to turn them off kapag may kasalubong.
Some persons are just so inconsiderate. Aba, the other day lang naka-low beam ako bigla akong hinigh-beam ng kaharap ko. Di I turned on my high beams to show him I was just using low beams. Aba, binusinahan pa ako at sya pa ang galit!!
Take note, my beams are casa-calibrated using laser ek-ek pa. Regular ang maintenance ko and I've told the service supervisor to check the angle of my headlights before.
June 18th, 2009 03:08 PM #82
hell no, Doctor kaba?
if you get about 10 or more reactions like that on dark provincial roads. consider the possibility that your casa doesn't know how to use their equipment properly.
kung hindi naman, baka light sensitive yung nakasalubong mo. or just a plain moron.
June 18th, 2009 07:18 PM #83
June 18th, 2009 07:48 PM #84
July 8th, 2009 01:57 AM #85
i use 50w on all the headlights of our car here at home then 35w on fogs.
wala naman po nag flaflash sa mga sasakyan namin except for our hi ace van pag may karga po or puno ng tao bumabagsak kasi pwet nun so tendency tatas ang headlight yung aiming ng headlight or focus mataas. so binababa nalnag yun . para di makasilaw
pag malaki ksi ang reflector like headlights it is better to use 50w
then kung maliit lang like regular fog lamps pwede na ang 35w. now kung projector better din 50w na lang kabit niyo kasi humihina ang liwanag eh
advantage ng hid unang una kitang kita niyo ang daan, relax ang mata niyo lalo na pag sa province at long driving. mas tipid sa koryente.
disadvantage naman po.
una pag outside warranty minsan yung supplier ng hid hindi nag bebenta ng parts kaya make sure niyo they sell parts din para hindi kayo oblige bumili ng buong set. at hindi fly by night ang supplier or seller ng hid madami kasi bigla naglalaho na tatak sa market
pangalawa hindi na pwede mag flash kasi nakakaiksi ito ng life ng hid
use your horns nalang when making a signal.
nakaka cause ng glare pag mali ang pagkabit or pag focus ng headlight. aim niyo ng tama
for h4 bulbs wag alisin ang cover
July 27th, 2009 09:17 AM #86
guy i need to know,
is it better to have an projector head lamps housing for HID?
im driving an f150 planing to have it change with HIDs 6000k siguro
should i get my reflector headlights change to projector para di nakakasilaw?
or should i just aim it low? im getting yung single beam lang (low)
yung isang auto ko nka hid din pero pinababan ko nlng ang beam.
is hid mor better on projectors or reflectors?
July 27th, 2009 09:53 AM #87
yes sir, mas maganda ang performance ng hid sa projector headlamps. mas maganda ang buga at hindi ka pa makakabulag ng tao kasi parang spotlight ang labas niya. pag kasi sa reflector, scattered ang light kahit na babaan ang aiming niya. unlike sa projector na controlled ang light scattering. as for single beam o hindi, the REAL hid are d2s lamps which is only a single beam. nagkakaroon lang ng high beam yun kung nakalagay siya sa bi-xenon type of projector. some good examples of bi-xenons are nissan murano, infinity fx-35 and 45, or those na nakikita mo na projector lang ang headlamp assembly niya at walang hi-beam na nakasupport.
ako kasi nagpa-retrofit, pajero ang sasakyan ko na gen 2. costly nga lang pero sulit naman at maganda ang porma
July 27th, 2009 10:15 AM #88
maliwanag HID using projector type housing kung reflector lang wala kwenta. nakakasilaw pa sa iba. pag umulan kawawa yun iba motorists. mas maliwanag pa regular halogens kun reflector type yun HL mo. Dami crv, fort na naka HID sabog naman ilaw
pero yun friend ko na new model fort ok lang lagyan ng HID basta wag lang gagawin HID yun high beam.
July 27th, 2009 04:33 PM #89
kung projector, there is a possibilty of a little nod. kung halogen, there is a big possibilty of noding it way deeper than a projector.
July 27th, 2009 05:05 PM #90
Advantage: maliwanag especially on asphalt roads
Disadvantage: mahal!
some HID units break down only days after the warranty expires (w/c is 1 year).
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
