Results 41 to 50 of 58
01 EX Ody
- 437
March 21st, 2004 07:15 AM #41noteworthy,
abrupt accelerations that spew out black smoke is not caused by the turbo. it is by the unburnt fuel since you accelerated it abruptly too. for the fuel to completely burn, acceleration should be done slowly and gradually. this after we did a test with a german instructor at TESDA.
with this action, it also does damage to your turbo's shaft and bearings.
Doc Diesel
Tsikot Member Rank 4
- Feb 2004
- 1,704
March 22nd, 2004 09:14 AM #43so dapat pala gradual ang acceleration/ suave ang hatak para di masyado agrabyado ang engine and turbo. cool, ganyan naman talaga ako magdrive.... on most ocassions
doc diesel, drop ko yung pajero sa Betan Davao bukas ng umaga
andy
- Jan 2003
- 2,979
March 25th, 2004 02:11 AM #45question lang po mga peeps... about sa abrupt stepping sa gas pedals... alam ko masama yun di ba? kakabwisit lang yun nag-eemission test... tama ba yun bigla sagad yun silinyador? pwede mo ba batukan yun nagtetest pag ganun? nang-gagago kasi eh... wawasakin makina mo... hehehehe..
March 25th, 2004 05:39 AM #46Originally posted by badsekktor
natanggal belt ng power steering ko..
March 25th, 2004 06:21 AM #47
alam ko may appropriate procedure yan. I'll try to find the manual. :D
March 26th, 2004 01:39 PM #48
naku, buti pala nabanggit nyo. ndagdagan na naman ang knowledge ko. i used to be "leadfoot" dahil dati gas fed ang madalas kong ginagamit. now i know. wala ba tayong mga book of tips on how to take care of our diesel engines aside from the owner's manual? kasi hindi reliable ang owners' manual, kulang ang mga info. thanks!
- Feb 2006
- 24
June 5th, 2006 05:16 PM #49how will I know if the turbo in a 4d56 engine work? I rarely accelerate my tacho to 2000 rpm. I usually drive 1500 to 1800 rpm * 50-70kph on hiways. I still haven't feel that kick in the engine or heard the "whistling sound" when I go above 2,000 rpm.
Need your info on this. Thanks in advance!
June 5th, 2006 05:32 PM #50
Sir, kung minsan talaga hardly felt ang pag kick in the turbo...but you'll know your turbo has had it when your rig starts pulling like a gutless pig. =) some mechanic even told me that you can really feel it kapag hirap na ang engine mo (just don't know to which extent)
too much white smoke can also be a culprit...
if you really want to see it...just remove the air hose from your intake...you should see your turbo/impeller at work and spinning really fast.Last edited by BeetOls; June 5th, 2006 at 05:35 PM.
Hybrids and EV
