Results 1 to 4 of 4
- May 2008
- 35
November 8th, 2008 09:47 PM #1SEC. 5. Mandatory Use of Biofuels. Pursuant to the above policy, it is hereby mandated that all liquid fuels for motors and engines sold in the Philippines shall contain locally-sourced biofuels components as follows:
5.1 Within two years from the effectivity of this Act, at least five percent (5%) bioethanol shall comprise the annual total volume of gasoline fuel actually sold and distributed by each and every oil company in the country; subject to requirement that all bioethanol blended gasoline shall contain a minimum of five percent (5%) bioethanol fuel by volume Provided, that ethanol blend conforms to PNS.
5.2 Within four years from the effectivity of this Act, the NBB created under this Act is empowered to determine the feasibility thereafter recommend to DOE to mandate a minimum of ten percent(10%) blend of bioethanol by volume into all gasoline fuel distributed and sold by each and every oil company in the country.
SEC. 21. Effectivity. - This act shall effect fifteen (15) day after publication in at least two newspapers of general circulation.
Approved,
JOSE DE VENECIA JR.
Speaker of the House of RepresentativesMANNY VILLAR
President of the Senate
ROBERTO P. NAZARENO
Secretary General
House of RepresenativesOSCAR G. YABES
Secretary of Senate
Sa mga di sigurado o ayaw gumamit ng biofuel, next year siguradong gagamit na kayo nito....
June 7th, 2009 10:27 AM #2
Vehicles equipped with carburetors may experience problems with E10 whether from Shell, Petron, Caltex, TOTAL, PTT, Unioil, etc. E10 is not recommended for engines with carburetors as it may "corrode" parts of the carburetor itself.
For most newer cars with fuel injected engines, E10 is not a problem but you may have to check with the car manufacturer to verify just to be safe.
June 14th, 2009 06:38 PM #3
Some gasoline stations in the metro are all E10 blended na.
Better check the pump before filling up.
- Apr 2008
- 537
June 14th, 2009 07:07 PM #4as of now wala naman akong problema sa makina ko dahil mahigit 1 taon na akong gumagamit ng E10 sa corolla small body na naka 2E carb engine maski corrosion sa mga parts na dinadaanan ng fuel maski sa hatakan at takbuhan parehas pa rin tulad ng dati na gumagamit palang ako ng unleaded
Yes Yes squeaking sound is heard when shifting only
