Results 41 to 50 of 75
June 25th, 2013 11:32 AM #41
Just this morning from the Phil star,a reliable source working for shell stated that a gasoline reading of Ron 91 is less.he said that it is 90.6 to90.9 being round up to 91 octane,in the long run your engine will knock .so to avoid this he mix his 91 with a 95 octane to a have aright ratio.
June 25th, 2013 11:35 AM #42
It should be no problem imo if your car minimum octane requirement is at 91.
June 25th, 2013 11:38 AM #43
June 25th, 2013 11:54 AM #45
June 25th, 2013 11:57 AM #46
hindi naman kasi exacto yan sir ni round off naman talaga ung 91 RON. just a small difference it doesn't really matter imo.
June 25th, 2013 11:58 AM #47
June 25th, 2013 12:07 PM #48
June 25th, 2013 12:40 PM #49
Knocking isn't a chronic problem that takes a long time to surface. The moment you use fuel that burns quicker than what your engine requires, it will knock. Likewise, once you change to a compliant fuel, the knocking should vanish.
It's not as if oil companies are cutting corners in octane to save on costs or anything. The additional cost of going from 91 to 93 is actually negligible, and the reason why everyone's mainstream unleaded is on RON 91 now is because that's what the law mandates.
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
