Page 9 of 54 FirstFirst ... 567891011121319 ... LastLast
Results 81 to 90 of 533
    #81
    hahaha. agree. same experience na friend ko with his motorcycle...
    nagfail daw ECU nya kasi nag under voltage yung bike every time he uses his upgraded horns
    That's actually possible. I changed my Pajero to PIAA air horns, the electrical shop had to run a new wire and relay to make sure it worked properly.
    The original wiring wasn't able to supply enough current and would cause a voltage drop across the line which meant the new horns hardly worked until the wiring upgrade.
    For a motorcycle big horns could have an even bigger impact on the electrical system. You can sometimes see bike headlights change in intensity depending on how high the engine is revving.
    #82
    OT,
    years ago,
    someone upgraded his then-new honda city's puny OEM horn, into something more... dramatic.
    tinirik siya.
    it would seem, some designer designed to run the horn's wiring with the AT trans' fuse wiring.
    the upgraded horn blew the fuse, thus freezing up the transbox.
    #83
    #84
    ... less than 1.8M...?
    sana, much much less.
    at 1M, it'll fly off the proverbial shelves.
    #85
    mas mura dapat sa toyota cross kasi mas cheaper daw puhunan ng e-power.
    Sa 1.3 to 1.4 million maganda-ganda na presyo. Pero kung mapababa mo 1.1 milyones eh yari na competition.
    Jun 2013
    #86
    Diesel for life!
    #87
    no more innovation. Mga surplus ng euro6 makukuha ng pinas. Hangang jan na lang future ng desel.
    and the basic tunog-lata desel eh magiging irritant pag dumami electric.
    Sasabihin = ewwwww so maingay.
    Watch out pag namaster na ng buong mundo electric technology eh magiging smartphone level babagsak pa yan around 200thou hahaha!!!!
    #88
    Toyota Allegedly Working On Diesel-Electric Hybrid Powertrain | Motor1
    Hehe Toyota rumored to be developing a diesel-electric hybrid! Parang tren ����
    Technically it's one of the most efficient drivetrains we can build (kaya nga ginagamit ng tren).
    #89
    ... only if one accounts for the weight of the materials used...
    but one must always consider the research involved in the development.
    parang duktor.
    the materials needed for the surgery are cheap.
    it's the labor that is priceless.
    Feb 2014
    #90
Hybrids and EV
