Results 121 to 122 of 122
Tsikot Member Rank 4
- Jan 2007
- 2,326
June 16th, 2010 03:29 PM #121How do you know your FC is OK if it has not been computed vis-a-vis non-ethanol?
'Dirty' gas is usually associated with water since particulates can be handled by the fuel filter if it's working. Ethanol is even more of a water attractant than pure gasoline. The main culprit of this is long storage. Hence, you are correct in gassing up at a busy station.
But then, there are also busy stations not among the big 3 ... and some of them have pure gasoline to boot.
- Jun 2008
- 120
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
