View Poll Results: Does a non-moving A/T car consume more fuel if the shifter is in D or N ??
- Voters
- 65. You may not vote on this poll
consumes more fuel in D
44 67.69% -
consumes more fuel in N
0 0% -
I don't know.
17 26.15% -
I would like a faux sunroof for my car.
4 6.15%
Results 11 to 20 of 44
September 21st, 2007 06:37 PM #11
I don't think it will starve atf if you put more on N. measuring atf level while engine running on D, N or P have the same reading unlike not turning engine on.
I think putting it to D won't make much difference for non-efi a/t's. since it doesn't have computer or sensors to detect it is running low on power that tells it to feed more fuel to compensate the felt load.
but putting D worn out engine support by a bit, brake pads by a bit.
and I would like a faux sunroof for my car.Last edited by rion; September 21st, 2007 at 06:44 PM.
- Jan 2007
- 4,459
September 22nd, 2007 01:33 AM #12
Tsikot Member Rank 4
- 2,716
September 22nd, 2007 03:17 AM #13i agree about higher fuel consumption with D engaged while the brakes are applied ... it is an additional 0.5 li/hr on my car as it needs more power for the additional load
but ...
with D engaged, brakes applied and car not moving, why do you guys say it tends to wear out brakes?
if the car is stationary, there is no rubbing friction between pads and rotor, no heat generated ... how do the brakes wear out in this condition?
September 22nd, 2007 04:03 PM #14
The application of brakes as you stop, and the constant pressure applied as the car is stopped. It wears out the pistons, and in some cases, can cause warpage of the brake discs if you hit traffic after a high speed run. It's not damage you can see right away, but it accumulates... lots of magazine testers and owners report warped brake discs before 100,000 kms on automatic cars.
On the other hand, I've never heard of tranny failure from putting it in neutral. Most AT failures are related to transmission fluid degradation and contamination from heat build-up due to traffic, a failed ATF pump, or excessively hard driving.
September 22nd, 2007 04:36 PM #15
etong liteace kaya ko napalitan ng a/t kasi yung former owner ang driving habits pala nya is retain to D... mga 10 mins kami nagkwentuhan, di siya nagbother mag-shift to N or P...
so ang kalaban lang talaga ng a/t is heat--kaya siguro some are equipeed with those air-ATF coolers (aside sa those you found underneath the radiator...)
and as they said--fluid kasi, kaya mas malaki ang losses...e ang a/t fluid ang nagpapatakbo sa kanya....
parang lumalayo na tayo sa topic.....Last edited by alwayz_yummy; September 22nd, 2007 at 04:40 PM.
September 22nd, 2007 04:54 PM #16
Actually, we're still on-topic.
The main contention for people not to put their cars into neutral in traffic is that it wears down the transmission... which is why we're discussing it.
Another contention is safety, daw... it's supposedly safer if you can move right away at the stoplight. Personally, I'd say this depends. If you're hit from behind and accidentally release the brake, the chance of you hurtling into the car in front of you or out into traffic is greater.
September 22nd, 2007 05:10 PM #17
ako i dont recommend leaving your AT on D--> i am a victim of being rear ended because some guy in my rear forgot that he's on D and released on his brakes!
fortunately it happend on my former lifted delica and he hit my rear under bar and luckily he did not dent it...
September 22nd, 2007 06:59 PM #18
September 22nd, 2007 11:04 PM #19there is no rubbing friction between pads and rotor, no heat generated ... how do the brakes wear out in this condition?
comparing our own A/T and M/T ride, mas malakas ang brakes consumption ng aming A/T.
in my case, it's faster to pickup speed on standing start traffic light to use N then flooring at D. than staying on brakes then flooring to D. because somehow when you put from N to D, you get a kicky start-up feeling. though I hear about brake torque but I have no idea what it means...
September 23rd, 2007 12:59 AM #20
so....ano ang tamang sagot? i even checked google but it had no answers for me...
