Results 31 to 40 of 56
June 1st, 2005 05:16 PM #32
Thanks Jim. There is a good discussion on how to purge your diesel engine using this product through the fuel line in this link:
http://www.mindspring.com/~houlihan/merc/purge.htm
Liqui-moly is marketed as Lubro-moly in US and Canada.
June 1st, 2005 08:17 PM #33
For everyone trying the product out, thank you! Let us know the results.
Tsikot Member Rank 5
- 3,144
June 2nd, 2005 11:07 AM #34Originally Posted by notEworthy27
malamang ok
June 22nd, 2005 03:09 PM #36
i was just wondering if most of you who tested this product used it directly to the fuel line or mixed it with fuel in the tank. wouldn't using it directly introduce air to the fuel system kapag tinanggal mo na yung fuel line from/return to tank? or would the effect be negligible?
June 28th, 2005 03:06 PM #37
Just wanted to share the results when I tested the product last saturday. As instructed on the can, i used it directly on the injection pump --- I placed the fuel intake and the fuel return hoses from the injection pump into the can of Diesel Purge. After that, I started the engine and then revved it at various RPMs. I continued doing so until the contents of the 500ml can was almost empty. When done, i reconnected the hoses back to the mail line. To answer Ram's question, air pockets created when connecting/reconnection the fuel hoses didn't seem to have negative effects. All-in-all, my personal observation is that there was a slight improvement on idling, vibration, emission, and response. The engine seems to run a bit quieter than before. I think that my engine can improve a bit more. According to the instructions on the can, if the nozzles/pump are really dirty, (which I suspect my nozzles are), you may need to use a second 500ml can of Diesel Purge. I only used one can.
One thing to note was that the main ingredient of Diesel Purge is Naptha. Just a background, there are two ways to produce biodiesel. The most common is transesterification and the other is hydrotreating tree oils. One of the main components in hydrotreating tree oils is Naptha. I personally suspect that Diesel Purge is just another Biodiesel---a B100. If you smell the product, it smells like biodiesel.
If you weigh the cost, it would be better to use 100% local biodiesel (B100) same way you do when using Diesel Purge in cleaning your injectors/pumps (direct to the fuel line). The 500ml can costs P220 at Planet Lube. IF it is your first time to use it, you may need 2 cans. That will be P440. A liter on SENBEL biodiesel is only P66. Chemrez's BD is P125.
June 28th, 2005 03:34 PM #38
Fuego 4x2: Where did you buy the Diesel Purge? Planet Lube? Where is Planet lube?
June 28th, 2005 03:47 PM #39
It's located in the BIR bldg West Avenue. I'm not sure what floor. I think it's the 15th. You can call Planet lubricants at 373-9337, look for teresa or jenny.
Tsikot Member Rank 3
- Dec 2002
- 636
June 29th, 2005 12:02 AM #40Mixed a whole 500ml can of diesel purge in my LC fuel tank prior to a long trip. Engine was quieter at speed, idling smoother.
