Results 11 to 20 of 24
- Jun 2004
- 476
December 18th, 2005 10:00 AM #11arb is right. Mas masama kung smoke ang lalabas when the oil cap is taken off. To be sure I suggest you get a compression test.
December 18th, 2005 08:28 PM #12
arb, paj4x4: hmmm. i don't notice any power loss naman and smoke is i'd say still normal. though i do need a change oil soon, due na rin eh. when we took off the oil cap, wala naman nangamoy na exhaust gas or smoke.
thanks! i'll have a compression test done na muna pag nagkaluwag. nawipeout ako this pasko eh. hahahaha.. :D
- Jun 2004
- 476
December 18th, 2005 11:07 PM #13Glad to be of help nugundam93. Pa compression check mo muna para sure. Gen 2.5 yung Paj mo diba. Di pa naman siguro due yan for an overhaul.
December 18th, 2005 11:25 PM #14
yup, gen 2.5. 73T kms na rin ang natatakbo niya. sana nga di muna for overhaul. :D
- Jun 2004
- 476
December 18th, 2005 11:29 PM #1573k kms pa lang - di pa nga siguro unless nag overheat ka na or nababawas na ang oil mo before the 5k km change oil interval. Yung gen 2.5 ko nasa 97k km na okay pa naman.
December 18th, 2005 11:33 PM #16
goodie! hehehehe. no overheating and oil naman stays at the same level, dumudumi lang nga as it's supposed to do. yay. :D
- Sep 2005
- 110
December 27th, 2005 06:13 PM #17sorry, medyo wala akong alam sa oto talaga eh... mines a 01 fieldmaster, 38T kms ang odometer nya.... kelangan ko na ba magpa compression test? if not, what are the signs na kelangan na? thanks
- Dec 2005
- 3
December 28th, 2005 10:53 AM #18Hello guys...may Starex Club ako..'99 model.55K na tinatakbo..2nd hand ko nabili...mga napalitan ko crankshaft, mga oil seals, hoses....Malaki laki na din nagagstos namin ni misis...First time ko humawak ng diesel engine...Paano mo malalaman kun dapat na i calibrate ang injector pump..? Tried na ihataw ang starex ko sa coastal ( i live in cavite kasi) ng 130kph.. Mga magkano nman...? May recommended shop ba kayo..?
tnx
January 3rd, 2006 02:41 PM #19
also looking for a recommended shop for 99 Toyota Hi-Ace. your suggestions will be highly appreciated.
- Dec 2002
- 2,335
January 4th, 2006 06:13 PM #20diesel engines: tama yung post. with regular maintenance you can run it for more than 200K actually without the need for overhaul. Pa-compression test mo kung may doubts and also pag kumakain na ng langis may white/bluish smoke na yan. Also pag overheating na coz baka may crack na sa cylinder heads. Kung yun may oil deposits ka na sa radiator and nababawasab tubig mo. Yan candidate na for overhaul but not necessarily a major one. Pag sa injector naman problema most of the time mausok na and you cant reach red-line sa sa tach. My 2cents
The Corolla Cross's interior, even on the GR variant, doesn't come close to the CX-5 or even the...
All New Toyota Corolla Cross
