Results 51 to 58 of 58
October 27th, 2004 08:04 AM #51
Trooper128,
Im on BD 5%. You only need to check your fuel filter during your initial use of biodiesel. Kasi baka may mga deposits na natunaw ng biodiesel at magbara sa filter. To be safe, just replace that filter. After that, your filter will be as clean as a new one if you use BD regularly.
PM mo si Garyq dito sa Tsikot. He sells biodiesel. I think he also delivers if you buy more than 4 liters. Anyway, PM mo nalang siya.
October 27th, 2004 08:51 AM #52Originally posted by notEworthy27
TROOPER128 ,better if you could check your fuel filter. baka kelanganin palitan. I'm on BD10. (10% mix)
wulf , sa petron philcoa meron? alin dun ang pumps na meron? kelangan pa bang sabihan ang mga nagkakarga or lahat ng diesel pumps nila meron?Last edited by wulf; October 27th, 2004 at 08:54 AM.
- Sep 2005
- 17
October 11th, 2005 03:14 AM #54"Hi guys! Need your help once more...
My brother is doing this thesis on biodiesel...If its really and advantage or not, and he needs the inputs of us users here sa tsikot. He is having a hard time running this survey coz most of the motorists still doesnt know this product. Kindly give me naman ur inputs:
Occupation:
Vehicle driven:
Biodiesel used since?
Effects of biodiesel:
Do we still need it since our fuel here in the Phils are now less sulfur?
I can set him up with the DOE people involved in this thrust if he is intersted.
Tsikot Member Rank 3
- Aug 2003
- 1,251
October 11th, 2005 10:22 PM #55Lex, please tell your brother to access the following, my research on biodiesel here in the Philippines. Meron din dito sa tsikot, pero mas updated sa kabila.
http://www.kotse.com/forums/index.php?showtopic=2718
October 11th, 2005 10:35 PM #56
Sir altec, lex888 was just quoting yung opening post in this thread. The "brother" actually belongs to Djerms, the thread starter.
I would assume na tapos na yung thesis niya by now because it has been 21 months since this thread was started.Last edited by Bogeyman; October 11th, 2005 at 10:40 PM.
- Apr 2004
- 663
October 12th, 2005 09:16 AM #57sir altec's finding on issues on filtering of the CME is very interesting. something we should be watchful of. this has been oberved on senbel biodiesel, and *they are looking into bioactive as well.
http://www.kotse.com/forums/index.ph...pic=2718&st=80
*altec, jaeger
- Dec 2006
- 64
August 21st, 2008 01:39 AM #58In my experienced po....proven ko na mas maganda pre blend biodiesel ng Flying V.
Dati, Shell at petron ako...ng minsan nag try pa ako mag add ng Bioactive enhancer, lalong nagumusok ang sportivo ko...
Pero ng magkarga ako ng Diesel sa Flying V eh , less usok talaga.
Try ko ulit petron without Bioactive, eh mausok kaya, balik flying v kami.
Experienced ko lang ito.
Bioactive, once lang akonag try, bumagsak pa. Full tank ng Ptron Diesel at 1 letir ng bioactive nilagay ko....mausok, kaya nag flying v ako.
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
