Page 98 of 116 FirstFirst ... 4888949596979899100101102108 ... LastLast
Results 971 to 980 of 1155
    #971
    Regarding mbeige's inquiry about a site for emissions & fuel economy data on B20 & B100 biodiesel, I just saw the following:
    Biodiesel is a form of diesel fuel that can be manufactured ... Mileage. Tips. Gasoline. Prices. Your MPG. Will Vary. Why is Fuel. Economy....
    http://www.fueleconomy.gov/feg/biodiesel.shtml
    This is apparently a US Government website and it only deals about Soya BD. Please note that B100 Soya BD produces 10% lower fuel economy and power. B20 produces lower 2% lower fuel economy and power.
    In simple terms, using B100 Soya BD means you will use 10% more diesel and B20 Soya BD will require 2% more diesel.
    CME or Coconut Methyl Ester (the BD made from coconut oil in the Philippines) appears to be the only BD that can deliver 10% fuel savings at 1%.
    In my case, I get >10% fuel savings even with 0.5% CME only. Please support my efforts to prove this nationwide so we can together show the world how good CME is.
    #972
    i bought biodiesel at sharkis yest. will try it on wed.
    accdg to them, there will b a price increase on feb. so get yours now.
    the 20liter i got is around 1344 petot
    #973
    Quote Originally Posted by mbeige View Post
    Do you have any sites that provide this info? Would you also know how much emissions difference there is when used at higher percentages like B20 and such up to B99?
    can't point you to a website but I've read an actual report done on CME (sample provided by the Philippines) and test done in Japan, 70% reduction in airborne particulates and 20% reduction in NOx from the emissions with a mere 1% (or 5% yata?) addition of CME in LSD. meron na rin ginawang study ang SAE (society of automotive engineers) of the US way back in 1998 (take note this is almost 10 years ago), specifically on exhaust emission and engine performance for a stationary diesel engine using coco methyl ester as fuel. subukan mo google, SAE report no. 981156. hopefully naka share na yung PDF file for free. 3 years ago, di pa eh, bibilhin mo ma yung report hehehe. hth
    #974
    Quote Originally Posted by pervagus View Post
    Ok, a direct consumer concern for a change.
    I presume that you poured in a 500 ml. bottle which gives you more or less a 1% blend for every full tank of diesel...YES
    .... You just have to check your fuel filter and replace it if the cleansing action of coco-biodiesel has deposited the sludge from fuel tank in it.
    Does it mean that I will change very often the fuel filter for using bioactive? For the fuel consumption there is no significant difference. My day to day city driving (cainta-pasig-pasay route) fuel consumption average remain at 7.5 km/liter (xwind 2002 with A/T).
    #975
    Quote Originally Posted by 3kings View Post
    What brand did you buy? BioActiv, Estrol or what?
    How are you planning to try it? At 100%?
    If 1%, mix 20L BD to 2,000L diesel (or 1L BD to 100L diesel.)
    I suggest you try 0.5% first for 3,000 to 5,000 km, then try 1%.
    If 0.5%, mix 20L to 4,000L diesel (or 0.5L to 100L diesel) -- mas matipid!
    Re: Price Increase - Don't worry about it. In a few weeks ALL diesel sold will be pre-blended with 1% as per the BioFuels Act. This will happen whether we like it or not.
    Pare, ingat kung 100% ang gagamitin mo. Balita ko nag-le-"levitate" ang tsikot para hindi magasgas ang gulong. Ang "fuel savings" at "pollution reduction" ay 300% -- WOW! Mahirap lang daw lumiko kasi walang "traction" ang gulong -- for this reason, the BioFuels Act only mandates 1%.
    Jul 2006
    #976
    Biogas.works & Rsnald,
    Thanks for your responses, I've been meaning to get into Biodiesel myself here in the US but like you said hindi ganun ka-efficient yung soy bean products nila as compared to CME. Right now we have ULSD, maybe it's the increased kerosene content in the winter diesel but I've had lower MPG so far (from 25 to 23MPG). I know that when they made fuel stations pump out ULSD my MPG was the same as before, 25MPG.
    Here's another question, that maybe you might know the answers to. I've heard that biodiesel will degrade rubber used in fuel lines (and perhaps, seals in the IP and related devices) over time. Of course, the rate of degradation will depend on the condition of the rubber, percent of biodiesel, and type of rubber lines used (fuel lines).
    Would you happen to know any info about the degradation of rubber fuel lines between CME and Soya BD?
    Here's something that may also be a good insight to using biodiesel:
    #977
    BioDiesels (BD) degrade rubber in fuel lines. But most (newer) vehicles now use a better type of rubber (viton?) and these are not affected by BD. In the US, where B20 and higher of Soya BD is recommended, the degradation will probably be higher. In the Philippines where 1% (or 0.5%) is recommended, the quantity is too minute to matter even if vehicles still have some of the older rubber parts.
    #978
    * mbeige
    on rubber degradation, di ko alam kung ano material of construction ng old rubber hose sa mga older model cars. para safe, palitan mo na lang ng rubber hose rated for gasoline yung mga rubber hose ng fuel lines mo.
    tama si biogas, viton will resist biodiesel.... but viton is not often used for automotive applications. it's too expensive. maybe for the higher end cars they're using it.
    simple test, put pure BD in a small open can, cut off a small portion of the rubber tubing where your fuel passes thru and immerse that portion in the BD. you'll see if it will swell or if it will breakdown the piece of rubber tubing overnight or over a few days. now multiply that rate of degradation by 2 or 3 times since the engine bay is hot so you'll have heat increasing the degradation effect.
    for the technically inclined, pure BD is as strong a solvent as xylene, or almost as strong as toluene. there's a scale of solvent dissolving power called kauri-butanol value, look it up on the net. Kerosene, or "gaas" in layman's term, is way way down in that solvency scale, but kerosene is a stronger solvent than pure diesel. so there's the comparison of pure BD vs. pure diesel in terms of solvency power
    Apr 2005
    #979
    Ang pinaka-popular na CME sa Pinas ay ang "BioActiv." Ang ipinagbibili sa Petron ay kulay berde. Ang CME na ginagamit ng Flying V ay "BioActiv" din pero iba lang ang kulay. Ang "Estrol" ay isa rin CME na gawa sa Pinas at approved ng DOE. Sa alam ko ito ay ipinagbibili ng SeaOil. Basta CME ang ginagamit mo, even if it is home-made like I used before, OK sya![/QUOTE]
    Thanks a lot sa reply Sir BIOGAS
    Yes! green container nga yon!
    #980
    Yo! Is it ok also if I will use it with old model L300? kailangan ba na ipalinis yung fuel line/tank? Paano ba ang tamang ratio kung gagamitin mo yung biodiesel?
Biodiesel Rulez!!! [ARCHIVED]
