Page 78 of 116 FirstFirst ... 286874757677787980818288 ... LastLast
Results 771 to 780 of 1155
    #771
    Quote Originally Posted by rsnald
    clarify ko lang 'tong issue na 'to. ang nalulubricate daw ng biodiesel is not the engine itself.. but the fuel injectors. by the time na makarating sa loob ng combustion chamber yung fuel, atomized na sya and in a split second, combusted na sya during the compression stroke of the engine. so hindi talaga yung engine pistons ang nalulubricate but the parts of the engine where the fuel passes thru before reaching the combustion chamber, w/c in this case is the fuel pump. yan ang contention ng ilang biodiesel users sa mga forums. ang isa pang sinasabi nila na beneficial effect is that the fuel injector tips are not fouled easily if you use biodiesel. so theoretically, less frequent ang calibration or change of fuel injector tips. just my 2 sentimos ;)
    Thanks for the clarification sir. In this case, less din ang palit ng fuel filter...Just my 2 sentabos.
    Apr 2006
    #772
    Hi mga brothers! Are biodiesels already available in the leading gasoline stations? or kaya I have to go to Banawe to buy these stuff? Pardon me for being newbie hehe
    I really wanna try it.
    #773
    Hi Initial-"Dito"
    I'm currently selling biodiesel.
    I've sent you a PM for the prices in case you're interested.
    :regards:
  4. #774
    psalm: sa mga b100 users na nag post sa Net the only problem they have is changing fuel line coz' eventually nag-le-leak. (BD is aggressive sa natural rubber)
    Feb 2006
    #775
    Quote Originally Posted by falken
    Biodiesel doesn't improve your mileage that much, the major benefit is improved emissions and better engine response.
    For old cars, heard the improvement can be as much as 25%? Can anyone verify this?
    #776
    Gary,
    Clarify ko lang. Ang ibig sabihin ng B100 ay 100% blend right? Kasi yung bd ko na kinukuha from chemerez ang nakalagay ay B100. Pero i'm just putting in 2% blend. Is this safe?
    Apr 2006
    #777
    hmmmmn...interesting fuel. Expensive but worth it!
  8. #778
    djerms: B100 is pure BD, not 100% blend coz' walang halo yun. In our case it's pure coconut methyl ester (CME). Tama yun note mo sa chemrez. That's B100 & if you put 1 liter of B100 to 10 liters of diesel fuel, B10 and tawag dun sa fuel na ginagamit mo or diesel fuel na may 10% pure biodiesel.
    mad max: old cars, depende kasi sa kondisyon nung engine. Talagang better emissions ang benefits nyan and also good fuel lubricity.
    #779
    Ah ok. Thanks for the clarification Gary. Kasi may narinig ako na May iba pang code ang BD from chemerez aside from B100 (which means na may mas less concentrated product pa sila am i right?).
    Anyway, ilang liters ba nilalagay mo before sa trooper? Is 2 liter enought?
    TIA
    #780
    Quote Originally Posted by MadMax
    eto actual demo I witnessed when I attended a conference on biodiesel sa Baguio about 2 yrs ago. Vehicle : a diesel-fed Kia sportage (ewan kung san nakuha, surplus siguro). Before loading with biodiesel, yung opacity reading ng emission tester , nasa 6.0 (or thereabouts). Then they disconnected the fuel line from the fuel tank and fed pure CME thru a funnel connected to the fule line. Revved the engines for a few minutes to get rid of the last traces of pure diesel, then they retested the opacity reading. It went down to around 2.6 - 2.7, still not passing the 2.5 maximum specs, but hey... that's already a 57% reduction from a few minutes use of pure biodiesel. And this was on an old/surplus diesel engine vehicle... Kia sportage diesel, wala naman dito sa pinas nyan.
Biodiesel Rulez!!! [ARCHIVED]
