Results 611 to 620 of 1155
- Dec 2005
- 71
March 1st, 2006 06:30 PM #611hey altec, as always bilib ako sa research mo.
jaeger, no problem. i think you might be able to use that table on the d4d woes thread i highlighted the lubricity property of biodiesel there. what do you think altec?
Tsikot Member Rank 3
- Aug 2003
- 1,251
March 1st, 2006 06:41 PM #612Originally Posted by styx189
- Dec 2005
- 71
March 2nd, 2006 09:15 AM #613Originally Posted by altec
sige, i'll ask aldrin to explain this further.
March 3rd, 2006 04:34 PM #614
Altec,Styx,
Partners, for clarification baka meron lang ako ma share, microns is the unit of measurement sa lubricity using an HFRR equipment ( high frequency resonance etc, etc sorry di ko na alam un R... hehe ). Actually there are 2 test method for determining the lubricity. Another is the BOCLE or the Ball On Cylinder Evaluator which uses grams as unit of measurement.
For the microns, ibig sabihin, the more scar / sugat created sa isang metal component which is measured in terms of microns ( masyado maliit kasi kaya in terms of microns ), it is more delikado sa engine. Ibig sabihin hindi maganda ang kanyang lubricity. If maliit naman ang scar / sugat that was created in a metal component, it means it has better lubricity.
Please remember that sa injectors, the clearance of the plunger sa walls is very small. Kaya nga it's very sensitive to moisture and dirt kasi even a small amount of those could damage the injectors. So lubricity is very important especially sa mga CRDi series. Another problems is if prolonged hindi na start ang diesel engine, diesel could volatilize and dried up the injectors which will cause stock up. Kaya if you do have gensets or old car on stocks, i suggest you to warm it up even for 5 minutes lang just to lubricate.
Guys, I sent some photos sa email ni M2M. Medyo mabagal kasi un PC ko pero i will try to email you all who attended the plant tour. Please give me ur email add. Thanks
Aaron_Drin
- Mar 2006
- 10
March 5th, 2006 02:27 AM #615gandang umaga po, just reqistered here, i like the topic. dto ako s baguio.
tanung ko lang kung may supplier ng biodiesel from SENBEL dto s baguio. nabasa ko s previous repleies n meron, d lang nasabi kung saan exactly. salamat po.
- Aug 2003
- 1,251
March 5th, 2006 09:18 AM #616Originally Posted by aaron drin
- Feb 2006
- 67
- Dec 2005
- 71
March 6th, 2006 10:01 AM #620Originally Posted by MadMax
Hi would just like to correct the statement, some petron stations are selling it already the rest will follow soon. it is available in 225 ml and 500 ml bottles
Yeah you're right about the radiator cap being relative to ambient, but IIRC the boiling point...
