Results 351 to 360 of 1155
Tsikot Member Rank 3
- Apr 2004
- 663
August 28th, 2005 12:21 AM #351sabi nung senbel distributor dito sa cavite sa makati pa daw niya kinukuha stock niya... alam niyo kaya kung saan sa makati? palagay ko meron na siya patong kaya P90/liter ang benta niya... baka masmura kung diretso sa makati kukuha.
- Jun 2005
- 325
August 28th, 2005 12:46 AM #352The Makati Distributor of Senbel is :
SHARKI'S INC.
Room 2J TAL Bldg.
Dian corner Edison St.
Makati City
Tel. 844-1643 / 819-0793
This is where I get my Senbel Estrol biodiesel - only P66/li. and the 20-li. carbouys go for P1,200.
Originally Posted by altec
On my 2nd full tank with my Everest, I used B2.8 blend (I put in 2-li. biodiesel in 71-li. full tank). I can notice the improvement vs. B1.4 blend (i.e. using only 1-li. per full tank) particularly during hard acceleration - mas smoother pa lalo and no grinding sounds nor vibration nor engine strain during hard acceleration.
Is there a law of diminishing returns kaya?, that after some peak blend point or saturation point, the improvements don't get that noticeable anymore?
August 28th, 2005 02:29 AM #353
Originally Posted by RafRaf
Napost na pala ni Jaeger ang complete details ng Sharki's.Last edited by falken; August 28th, 2005 at 02:55 AM.
- Apr 2004
- 663
August 28th, 2005 02:02 PM #354thanks guys... found out na sa JC Care in Makati siya kumukuha. binalikan ko ulit yung link na post ko some time back and found some more likely senbel distributors that I can try... siguro tawag-tawagan ko muna sila kapag lumuwas kami sa Mandaluyong (long distance kasi kung sa Cavite).
August 28th, 2005 05:54 PM #355
I saw this on cableTV while vacationing here in the U.S. (Trucks! on the SPIKE TV NETWORK) and the TV segment showcased a company selling a personal biodiesel production system. Compared to diesel prices at the gas stations they showed how economical it was to use this system on a long term basis. You can see the details of the device here: http://www.biodieselsolutions.com/pr...uelmeister.asp
Do you guys think this would be a good investment for, say a group of diesel enthusiasts to use instead of purchasing biodiesel from the two local producers? I'm just not sure if there would be a readily available source of vegetable oil from the restaurants to be able to produce a regular supply of biodiesel.
Also, I realized that with the rise in oil prices even the American hardcore truck enthusiasts are exploring other ways of minimizing their fuel expenses. We've known about biodiesel in the Philippines for several years now but the Americans are just beginning to appreciate it because of the rising oil prices. The TV segment even showed pure biodiesel being used on a 2001 Dodge full-sized, diesel pickup truck(?) and showing how superior it was to petroleum-based diesel fuel in terms of power and fuel efficiency (they even showed the truck doing a burnout of it's rear tires and how little smoke it emitted). They didn't discuss though what effects pure biodiesel would have on their rubber fuel lines and other such effects previously discussed in this thread.
August 28th, 2005 05:59 PM #356
Here's a brief episode description:
http://www.truckstv.com/show_details.aspx?iid=4996
- Aug 2004
- 243
August 29th, 2005 04:13 PM #357been thinking of using bio-diesel.. but aside from clean smoke.. is there a fuel efficiency gained on using bio-diesel?
thanks..
- Apr 2004
- 663
August 29th, 2005 04:48 PM #358Originally Posted by katsudon_ph
http://www.chemrez.com/ActiveBD/Bioflash.htm
- Aug 2004
- 243
August 29th, 2005 06:36 PM #359but did you actually gain extra mileage and does it compensate vis-a-vis the cost? meaning is it worth it? tnx mga sir
- Mar 2005
- 62
August 30th, 2005 12:54 PM #360anu difference nung BioActiv from senbel? Is that the biodiesel itself?
nu mas advisable? I use this product o use na lng ung pre-blende ng flying v?
2nd Gen Is the Kia Niro coming to PH with a 1.6L Hybrid? | Autoindustriya...
Kia Philippines
