Page 32 of 116 FirstFirst ... 222829303132333435364282 ... LastLast
Results 311 to 320 of 1155
  1. Heretic Guest
    #311
    What gasoline stations/companies are already selling them? Price per liter?
    #312
    Quote Originally Posted by kuyapete
    question lang po... biodiesel cleans the engine diba? which in turn will make your filter dirty on the first use because it will remove all the smudge in your engine. is it advisable to use it after ko mag PMS sa casa? or do I have to wait until my next PMS to use it para isang palit lang? Im driving an Innova by the way, just so you know the engine is quite new.
    IMO, use biodiesel now, since the Innova is new, I don't think there would be any smudge to clog your filter.
    #313
    To find a biodiesel outlet near you, click on these links: (courtesy of RafRaf)
    http://www.doe.gov.ph/alternative/Estrol.pdf
    http://www.doe.gov.ph/alternative/Bio-activ.pdf
    May 2005
    #314
    Last sunday i gassed up at Flying V E. Rodriguez branch near banawa. The Price per liter is 30.50. Regular diesel is 29.40 ata. My fear is baka sinasabi nilang blended na ito pero in reality is inuubos pa lang nila yung old pure diesel stocks nila. Alam niyo naman ang iba diyan kung makakalamang, manlalamang
    Apr 2004
    #315
    Quote Originally Posted by falken
    hulog ng langit!! thanks raffy! and falken!
    btw... which is cheaper? manually mixing the biodiesel or to just fill-up on FLYING-V????
    May 2005
    #316
    re-cap mga tol...
    1) masmura ba na yung blended diesels na ang bilihin ko or bili ako ng "pure" tapos iblend ko nalang sa commercially available?
    2) san makabili ng "pure"? mga sellers, pakitext naman ako sa 09209106289...
    3) ano ideal blend? may 1% kasi then may 10%... pwede kaya 50% para lang luminis makina ko then ibaba ko sa 1%?
    May 2005
    #317
    Bakit parang iba iba ang presyo?
    FROM INQ7.net--->
    "Coco-biodiesel currently has three blends, depending on the amount of CME mixed with diesel.
    The B1 variety is a one percent blend, the stronger B10 has 10 percent blend. A B100 meanwhile is pure coco-biodiesel.
    These are available in select gasoline stations in Metro Manila and some provinces.
    For immediate results, Lao suggested that a first-time user initially fill up with the B10 blend.
    Later, when the engine is already "clean," he may start using the B1 blend.
    But there is a downside.
    The B1 blend, now available in five Flying V gasoline stations in Metro Manila and select Seaoil stations, costs about P65 per liter, or more than double the current price of diesel which ranges from P29.40 to P31.
    A B100, now available in one-liter bottles in some 192 gasoline stations and 110 direct selling outlets of manufacturing firms, sells at more than P120 per liter. About 10 coconuts would be necessary to make a liter of B100."
    May 2005
    #318
    Quote Originally Posted by Leroy Brown
    Mali ito, nagpagas ako sa flying v nung envirotek (this is what they call the biodiesel blended fuel) ang price per liter is around 30.50 ata, a few centavos more than the pure diesel.
  9. #319
    meron na pala sa BF di ko alam? hanapin ko na lang yung philtrak. tnx sa link!
  10. #320
    Senbel Estrol 9178554454. Next week dating ng stocks. Puro carbouy (a few left coz may mga nag pre-order na) and a few litro.
Biodiesel Rulez!!! [ARCHIVED]
