Results 1,021 to 1,030 of 1155
- Feb 2006
- 67
February 15th, 2007 10:09 AM #1021
- Feb 2006
- 67
February 15th, 2007 10:14 AM #1022I believe the export was done last quarter of 2006, when coconut oil price was lower.
FYI, the Biofuels Act states that the 1% blend applies to "all diesel engine fuels sold in the country". I interpret this means all diesel engines, regardless of whether it's used for vehicles, gensets, power plants, ships, etc.
Full text of the law at Republic Act 9367. See section 5.3.
- Feb 2006
- 67
February 15th, 2007 10:25 AM #1023Dr. Kamiya, in quoting an EROEI of 3:1, you generalize using the term "biodiesel", when in fact not all biodiesels are not created equal.
You quote the low EROEI of biofuels to conclude they are not viable alternatives to fossil fuels. That's the line the oil companies keep repeating to us. The fact is, no technology (solar, wind, etc) can match fossil fuels in terms of EROEI. So we should just give up and stick to buying and using fossil fuels, right?
But what about the effects on our environment?
Quoting here an article from the Inquirer, http://opinion.inquirer.net/inquirer...ticle_id=48746:
"Taking the opposite tack is a lobby group funded by one of the world’s largest oil companies. The Guardian UK reported that the American Enterprise Institute, an ExxonMobil-funded think tank with close links to the Bush administration, offered scientists and economists $10,000 each to undermine the IPCC report.
Climate scientists said the move was an attempt to cast doubt over the “overwhelming scientific evidence” on global warming."
Makes me really sick.
February 15th, 2007 12:25 PM #1024
- Dec 2006
- 81
February 15th, 2007 05:23 PM #1025Mahal mag-testing ng 1% CME, specially if you buy CME for P74 per 500ml bottle. This is same as P150 per liter.
I suggest mixing 500 ml of CME with 100 liters of Diesel (0.5%) instead of just with 50 liters (1%.) This way you save money and find out what 0.5% can do for you (mileage wise). Get an emission report too and keep it.
Later when ALL diesel sold in the Philippines is 1% CME, find out your new mileage and new emission and compare data from 0.5%.
Sigurado ako, makakatipid ka pero hindi do-doble ang fuel savings & emission reduction. Sa akin pareho lang ang lumalabas na savings base sa "simulated dyno" testing of both blends after more than 8,000 km of tests.
February 15th, 2007 08:42 PM #1026
Thanks Gary & Niwde.
Ilan na nga ba ang dapat ko ilagay sa 72liter tank? 5% ba or can I just add 1%? Main purpose is just to keep my lines clean and avoid early calibration and injection cleaning.
February 15th, 2007 08:44 PM #1027
djerms... 1% would do...
pwede din yung suggestion ni biogas.works na 0.5%.
- Feb 2007
- 2
February 15th, 2007 11:23 PM #1028hi to every one,
Napadpad po ako dito kce gusto ng parents ko ng SUV worth 1M down,and pls help me. about the biodiesel i use it for 1 year na. home made lang po with the help of my uncle Dr. Rico Cruz. 100% to 10% na test ko na.
http://www.pia.gov.ph/default.asp?m=...0525.htm&no=56
http://services.inquirer.net/mobile/...37282-xml.html
- Dec 2002
- 2,335
February 16th, 2007 12:52 AM #1029
Tsikot Member Rank 3
- Aug 2003
- 1,251
February 16th, 2007 10:48 AM #1030OT: Garyq, ok lang, nakakalito mag costing ngayon dahil sa up and down price of diesel. Yung homebrew, I decided to terminate my research and just mix the homebrew into our overhead tank kasi namatay yung motorpool supervisor ko, so di na accurate yung monitoring ng testing. Siya kasi yung ine-entrust ko sa mga research ko to implement. Siya nga yung unang nakadiscover yung problema natin with the other brand, remember that?
Back to topic. Regarding the biofuel law, I checked with chemrez and they say the law clearly states that all diesel has to be preblended. They are still discussing with some other industrial suppliers and haven't finalized.
Then again, I saw a news article today that the department of agriculture is doing a research report on coconut status if we will have enough coco plantation to supply the new law. 1% now, 2% in a few years time. Right now, CME has gone up, even coco byproducts like copra has gone up a lot. And the law hasn't really taken off yet.
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
