Page 42 of 211 FirstFirst ... 323839404142434445465292142 ... LastLast
Results 821 to 840 of 4201
    #821
    Quote Originally Posted by s0nnyb0y View Post
    sino po si landrolanzo? any contak number?
    Anyway, I got the contact info for TARTARINI kits... they have what you want... don't be shocked at the prices though.
    West Orient Corp
    Tel 641-4473 / 09178818800
    #822
    is it advisable to have a brand new car (tucson) converted right away. I was thinking of tartarini. Is there a comparable brand for this type of lpg conversion. tartarini costs 60k + evat.
    thanks
    Jun 2006
    #823
    Quote Originally Posted by vojdiaz View Post
    thanks
    For me, its not advisable to convert a brand new car. You lose your engine warranty. But its your car so its your call.
    An alternative to Tartarini is the conversion kits from Turkey. They offer similar kits, not sure on quality and performance. I think they are cheaper than Tartarini. They are located beside Big Berts Ortigas.
    Oct 2003
    #824
    gud am!
    napaconvert ko na yun spacewagon(carb) using tartarini kits. pano nga pala ang tamang pag switch from one fuel to another? ex. from gas to lpg---kelangan ko ba i neutral (shut all valves) para maubos gas sa carb hangang tumigil makina tapos tsaka ko ilpg. and pag lpg naman ganun din neutral muna hangan tumigil tapos switch sa gas. hindi ba nakakasira ng makina pag nauubos gas?
    thnx
    Jun 2006
    #825
    Quote Originally Posted by boydapa View Post
    gud am!
    thnx
    Di mo kailangan ubusin ang gas sa carb. Just switch from one fuel to another. May valve na magcocontrol ng fuel delivery.
    #826
    gud am!
    thnx
    I just switch directly over between gasoline & lpg with the engine running. The problem with switching from LPG to gasoline is a few seconds of the engine running rich (because of leftover lpg in the system).
    i dont think so, it would make it hard to start the engine again on LPG though.
    #827
    gud am!
    thnx
    Bro, magkano inabot sa pacoconvert mo ng spacewagon mo? yun sa amin '92 model ang lakas sa sa gas. Saan pala inilagay yung tangke ng lpg?
    #828
    Quote Originally Posted by sequoia View Post
    Carb engine conversions costs around P20k to P24k depending on who you get your LPG conversion kit from and how good you can negotiate for a discount.
    The LPG tank is mounted in the trunk.
    Oct 2003
    #829
    ----yah totoo yan! ang lakas sa gas netong oto na ito kainis lalo na pag city ka lng. mga 5 to 6 km per liter ata or less pa. ano consumo mo?
    kaya nga eto pinaconvert ko na. buti nlng carb lng gamit neto kaya mas mura kesa efi o sequential kaya take advantage. 25k ang binayad ko TARTARINI(Italy) kit ang kunin mo gaya ng sakin at ang tanke na ibibigay sayo hindi local gaya ng iba. tapos kng feeling mo natatakot ka na may kasamang tangke sa 3rd row seat sabihin mo donut yun tank mo para ilagay sa ilalim dun sa spare tire kasi yun ang original plan ko kaso ang tagal nila magkaron ng delivery eh sa inip ko pumayag nain ako sa 3rd row ilagay kasya yan hindi tatangalin ang 3rd row swak na swak sa toolbox sya.
    eto num ni ric sbhin mo nirefer ka nun nakaspacewagon silver na kinonvert nila 0917-8125966 sa tomas morato lng sila qc
    bigay ko sa susunod yun num nila nakalimutan ko eh
    #830
    Pareho tayo ng consumption sa city drive. Pero ganda pa humatak ng makina kaya nanghihinayang akong ibenta. Wait na lang ako sa donut na tangke. Salamat sa iyo at kay GH. Btw, yung nilagay sila sa may carburador di ba? paano na kung gusto mong ipa linis o overhaul sa may kamuning. Kaya kayang tanggalin at ibalik?
    Oct 2003
    #831
    by sequoia
    yah matatangal yan madali lng ganun din worry ko dati eh. may donut na ba daw sila? palagay ka na para 2 na to na same unit. sa west ave qc yan. may mga nagpakabit narin sa kanila na member ng tsikot. dito ko rin sa thread na ito nakuha address nila. ok sila magkabit hindi bara bara. i suggest magpalagay ka grounding wires malalaman mo difference pag nagpakabit ka ng lpg before and after grounding wires installation
    by Ghosthunter
    West Orient Corp
    ETO pala yun number ng pinagpakabitan ko nakalumutan ko hehe binigay na pala ni GH
    #832
    yung friend ko pinagtanong ko. nakausap nya yung italian sounding ang name na owner daw. padating palang yung donut tanks at additional 5k daw pag yun ang ipalalagay. imported kasi kaya may extra bayad
    #833
    those "donut" tanks will take the place of your spare tire. Plus side is your trunk will have the same space. Down side, no full size spare.
    #834
    What's really the difference between the italian EFI kits and the korean EFI kits aside from the price?
    are there really differences in performance, workmanship, efficiency?
    #835
    Quote Originally Posted by afg598 View Post
    The basic kits (type 2) are similar to each other including efficiency are basically carb type kits with a box to disable/enable the engines gasoline fuel injectors. Engine performance is slightly lower when running on LPG as compared to running on gasoline. It is noted that this kit type is a bit sensitive to the condition of the engine's air filter so regular cleaning of the filter is recommended to maintain optimum performance/efficiency.
    The more expensive kit (type 4) is a true LPG-EFI system which works nearly the same way as your engine's factory fuel injectors. It has individual fuel injectors to deliver the "correct" amount of LPG fuel to each cylinder. This type provides a slight performance improvement when running LPG while providing the same level of fuel consumption. I assume this type of kit is less sensitive to the condition of the engine's air filter.
    The only main difference between the italian and korean LPG kits is the filling connector.
    Jun 2006
    #836
    best to have the tank draining done at the LPG service stations and not DIY. So far I haven't done a system drain. Based on my computations, I should be due by August of this year.
    But putting vinegar inside the tank... how does that make the LPG less volatile? Won't it just lead to rust forming on the inside of the tank and possible acidic fluid contamination to the rest of the LPG system?
    ghost, morethan a year na lpg sa kotse ko, hindi ko pa pina-drain, okay pa rin naman takbo ng kotse ko, humaharurot at lumilipad... kailangan pa ba iyan?
    #837
    Quote Originally Posted by chuaed View Post
    If you have achieved 10,000km on your system, I think I read somewhere that its recommended to drain the LPG converter of any water that has accumulated in there. I dunno about the tank itself though. I would ask at NAIADSS when I would pass by their area.
    The drain plug is the bolt/screw under the converter. It might be difficult to reach depending on how it was installed in your engine bay.
    My computations assumes around 200km per week for a year to achieve roughly 10,000km.
    Jun 2006
    #838
    siguro lampas na sa akin dahil morethan 350 - 400 km per week takbo ko...
    #839
    so, basically, there's no difference in the italian or the korean kit except for the connector?
    ano kaya mas reliable?
    i was thinking of fitting one on my samurai.
    #840
    Quote Originally Posted by tebs View Post
    Well, I haven't seen one blow up on the road yet due to installation or factory defects.
    The Korean version would leave a smaller hole in your body as compared to the italian kit. But the italian filler is "flatter" than the korean type. The korean version is easier to place inside the gasoline filler hatch/cover on a typical sedan. The italian version might need to be placed on the fender itself if the area around the gasoline filler is not wide enough.
Auto-LPG Conversion Thread
