Page 181 of 211 FirstFirst ... 81131171177178179180181182183184185191 ... LastLast
Results 3,601 to 3,620 of 4201
    Oct 2003
    #3601
    mga bossing ngayon palang ata ako magtatanong sa tinagal na ng lpg conversion tartarini ko on my carbureted car.
    anu ba yun screw na malaki sa vaporizer(yun malaking bilog sa engine bay???) at may maliit na screw na katabi yun anu din yun?
    paano pagpihit nun malaking screw? clockwise rich tapos counterclockwise lean tama ba? atsaka yun small screw thanks!
    #3602
    Quote Originally Posted by boydapa View Post
    Mixer or Vaporizer? ... pareho bilog yun.
    I assume mixer...
    Clockwise is "close", counterclockwise is "open".
    Oct 2003
    #3603
    thnx
    nakalimutan ko na ksi tawag dun since pinagawa ko conversion
    its that huge round thing on the engine bay about 8inches in diameter and 3 inches thick. it has 2 screws, 1 big and 1 small
    ito yun 2 screw na inaadjust ng installer pra timplahin yun rpm lpg mixture
    i noticed pag inikot mo yun screw clockwise tataas rpm and up to agad mamamatay na yun engine. that same screw pag inikot ko naman counterclockwise tataas din idling and pag sinagad mo pa mamamatay na engine.
    what is this screw? function? is this an idling screw or an air fuel mixture screw? my car is running rich matapang amoy kasi paano ba mag adjust sa screw na ito?
    pati narin yun maliit na screw na ginagamitan ng screw driver paano din gamitin yun
    kelanagan natin kasi matutunan mga nakalpg kung paano inadjust eto personally
    thnx again!
    #3604
    VAPORIZER:
    MIXER:
    #3605
    thnx
    thnx again!
    Personally, I would rather go to the installer or LPG fuel/service station to have the vaporizer adjusted.
    Sometimes, its not the adjustment but the diaphragm (needs replacement eventually) of the vaporizer that is giving you the problem.
    Oct 2003
    #3606
    ok sge na nga balik sa me sa ambi.
    gzto ko sana matutunan how to turn those screws
    pwede ba magpatune up sa greenfuel otigas kahit di ko sa kanila nakuha ganun thnx
    #3607
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format & grammar. Use proper sentences and paragraph construction. If your message posted is hard to read, less people will read it & respond.
    Read the RULES.
    Ignorance is NOT an excuse.
    Repeated offenses will lead to banning.
    [/SIZE]
    #3608
    Check with the shop/station. Some will give the tune up service for free as long as you filled up your lpg tank from them like CLEANFUEL (along Shaw Blvd, near Nueve de Pebrero)
    Oct 2003
    #3609
    Hello all,
    just to share.
    i have an EU type filler.
    i filled my LPG tank full and when i reached home, i heard a whistling sound at the rear and as i suspected, the filler was the culprit.
    i immediately thrust the middle ball of the filler using a ballpen and voila, the whistling sound stopped.
    Is this a sign that i have to change the filler?
    My last LPG refill was again normal. No whistling sound.
    Car: Outlander
    Kit : Greenfuel
    Installed: June 23, 2008
    Savings since 2008: 55,209.36 pesos
    #3610
    I doubt if you need to change the filler. Maybe something got stuck inside the filler itself? Anyway, if there was something, it would be in the lpg tank by now.
    May 2008
    #3611
    Quote Originally Posted by aamd View Post
    Hello all,
    just to share.
    Car: Outlander
    Kit : Greenfuel
    hi aamd.
    that happened to me before.
    culprit: rust on the bearing ball on the filler valve that made the valve sealing ineffective. (some rusting occured after i lost my filler cap)(i suspect the gas boy did not cover it back).
    my solution: after poking the filler valve, i sprayed some lubricant to fight rusting. then i got a new filler cap. (now, i uncover/cover back my filler cap to prevent losing it again coz it's not easy sourcing out a simple filler cap for lpg.)
    never had the same prob anymore. my lpg kit was installed june 2008 at greenfuel too.
    OT: bro, are you the one i met at speedlab before with the lpg-equipped rav4?
    Oct 2003
    #3612
    I see. Rust is the culprit.
    *g26
    Yup. I maintained an LPG RAV4 before. Sadly, i have to let go because it wont fit in my garage anymore.
    Jan 2008
    #3613
    question:
    may nakapag pakabit na ba ng LPG dito for Toyota Fortuner?im planning to install it. ano kaya masa-suggest nyo? or should i stick to using gas?
    thanks
    #3614
    Quote Originally Posted by tucson88 View Post
    question:
    thanks
    Based on the Auto-LPG users list:
    http://tsikot.yehey.com/forums/showt...t=51801&page=6
    There is at least one person (in tsikot) that have an Auto-LPG Fortuner.
    Aug 2006
    #3615
    For a Toyota Fortuner, I saw one at GreenFuel fitted with whooping 75 Liter toroidal tank, fitted like a spare tire underneath.
    #3616
    Quote Originally Posted by g26 View Post
    hi aamd.
    Same problem happened with my filler and it also happened after i lost the filler cap.
    May 2010
    #3617
    sa GreenFuel po ba pwede magrequest nag additional bracket doon sa tank (donut) para additional protection? ang pagkakaintindi ko kasi ay magbubutas lang sila sa flooring tapos doon ebolt and wala na ata additional bracket na flat or round bar. sa mga nagpakabit na dati na innova, nagpalagay ba kayo ng ganto? so far hindi pa umaalog un tank (55L)?
    i'm narrowing my list of installers kasi and will have my innova converted within this month.
    TIA.
    May 2010
    #3618
    next week is my green day at greenfuel. 2009 innova sgi kit 65L tank. hay finally.
    #3619
    Quote Originally Posted by Louga View Post
    good luck, just post your feedback , im also planning to install for my car
    Aug 2006
    #3620
    TIA.
    I did my own tank cage at my neighbors welding shop, it has a fabricated 2" flat bar and 1/4" round bars steel cage and bolted on the chassis, so there's no drilling on the flooring. I spent P1K for the fabrication.
    I initially paid 30% on the kit and ask permission from Mike if I can bring home the tank first so that I can have my own tank mounting and they agreed. When the tank mounting was done, then I head back to Mike and paid the full amount and the installation just took less than the whole day.
    So far I'm still happy and enjoying the SGI kit
Auto-LPG Conversion Thread
