Results 1 to 20 of 4201
Threaded View
    May 2007
    hector angel,
    you asked if carbed cars could be installed with SGI. The answer is yes but the technology may have to be assembled from various suppliers and will require a "stand-alone" ECU with programmable firmware.
    Also the resulting installation will only approximate (in some cases) exceed the original petrol performance if the engine itself is modified to work as dedicated system.
    I am currently assembling such a system and will begin installing on my 1985 MB 200 W123 sedan probably by next month.
    Actually if you already have a venturi kit installed -- the boot end (tank multivalve and vapor box) remains the same and usable.
    The "front-end" will need a new regulator, fuel rail, and the vapor injectors tapped directly into the manifold. Its probably wise to get the front end as a set. Prins of the Netherlands has the best injectors which are OEM from Keihin of Japan, makers of injectors to major manufacturers.
    Prins-Keihin may be found at:
    Het VSI systeem
    SGI systems are also available from:
    http://www.brc.it/Default.aspx?&lang=en
    Autogas Italia s.r.l. Home LPG EASYJET KIT Sequential injection system
    LPG/Autogas Conversion Equipment: The Bigas SGIS PLUS system.
    Vapor Injectors are also available at:
    Gas Injection Technologies Pty Ltd :: LPG, Propane Fuel, Hi-Performance Automotive, Injection
    Tartarini Auto - Products list
    The stand alone ECU may be found from any of these vendors:
    MoTeC Advanced Engine Management & Data Acquisition Systems
    Autronic sistemi elettronici
    http://www.necam.nl/english/index.html
    You can get more from Voltran at:
    Voltran LPG - Voltran Autogas Equipment
    To find what it takes to modify a petrol car to dedicated autogas, take it from Ford Motors of NZ at:
    Shell Gas LPG New Zealand
    Enjoy your window shopping!
    steve
    PS. May I have the name and address of the Pinagbuhatan installer? I live in cainta and would like to visit with them soon!
Auto-LPG Conversion Thread
