Just came from Autogas Power. They are located in Scout Boromeo near ABS CBN right side if coming from T Morato. Maliit lang siya. Located in an office building, ni walang work shop. Sa parking lot sila nagkakabit. Saw them converting an Optra. May nakapark din na F150 na converted na.
Talked to Paul, according to him they carry Tartarini Auto lpg kits from Italy. He said that they follow Euro standards and that their kits are 4th generation compared to 2nd generation from the Koreans. Closed loop system daw ang gamit nila. Looked at the 2 cars and got some brochures.
According to the brochure, the kit has 6 components.
1. LPG regulator
2. Rail of injectors. They install lpg injectors. According to the brochure, it matches the vehicle requirement, distributes equal amount of gas to each cylinder and is electrically controlled.
3. Filter to hold back impurities. Replace daw at 60,000 kms.
4. Absolute pressure sensor
5. Sequential Electronic Control Unit or ECU. Quote brochure "The electronic control unit of the multipoint sequential system directly processes the injection timing of the original petrol injectors, transforming it into injection timing for the gas injectors. In this way the strategies defined by the vehicle manufacturer are guarnateed in terms of driving conditions and emmissions. It is equipped with effective and functional diagnosis system and is pre-arranged to meet OBD norms."
6. Change over switch. Used to switch from unleaded to lpg.
Impressed ako sa trabaho. Mukhang malinis ang pagkagawa nung 2 kotse. Sabi nila na sasali daw sila sa autoshow sa Sept at BMW ang ipapakita nila na converted. May naconvert na daw silang Expedition.
I saw the injectors, regulator, ECU, filter and switch. Yung tank comes with seolonoid valve (tama ba spelling?) and pressure release valve. It is also fitted with an exhaust hose to clear out any excess gas.
Start niya yung F150 using gas then it switched to lpg after a few seconds. Saw this on the change over switch and the gas smell went away when the lpg kicked in. Did not hear or notice any change from the car during the switch. He demo several times by using the switch to go back and forth from gas to lpg.
So far I think its a very good system. Its superior to what Naidss uses. Ang catch: MAHAL!!! For my car 2.0 V6 quote ay 75,000Reason is expensive parts: ECU and will use 2 sets of injectors.
Per my estimate, it will take over 2 years for me to recover the cost of the kit. Is it worth it? I honestly don't know. Ok kasi it will maintain the original parameters of the car but at a price. What do you think, help naman.
I am still looking for the best option out there. I hope someone can give me the location of Macro or their tel number. The number previously posted is wrong.
Theveed, can you possibly post the tel no of the new shop beside Big Berts?
hmmm... i'm very interested... please give us details and elaborate naman... maybe you have pictures and proof that may nagpa convert na sira na ang makina ngayon? dahil ayoko mangyari sa kotse iyun sinasabi mo eh... okay... thanks
