Quote Originally Posted by artpogi View Post
Ghost,
yun ba mga naka LPG fuel system na, pwede din ba ibalik sa original (gasoline only) kung sakaling ayaw ko na ng LPG?
thanks
assuming you are not talking about a product refund/return...
Yes, you can simply switch the engine to run either on LPG or gasoline.
You can also have the LPG conversion kit removed BUT the holes drilled to mount the LPG tank and filler valve will need some body repair work if you want those to be covered up.
