2 or 3 weeks ago Xoom replaced my stock valtek injector with rail apache to improve performance and cure my issue on delayed acceleration.
- Injector: 3ohms Rail Apache 2 x 2-cylinder were used to position it near the manifold.
- Length of Injector hoses now reduced to almost half. Its now around 4 inches.
- Re-aligned to reducer to make it vertical in position to improve flow (that's how they explained to me). Before it was horizontal.
- replaced most of the hoses to make it uniform.
- inayos yun ibang wiring ko at pinaganda. may natira na lang kaunti don malapit sa selenoid. sa pag balik ko na lang siguro don.
-tuneup
Cost me almost 6k.mas mahal kunti yun 2 x 2cylinder compared with 4 injectors in one rail.
issues resolved:
- delayed acceleration. now I can instantly feel the power pag pinitik ko lang yun accelerator during traffic, or sa mga inclined area like parking or natrapik sa flyover.
- smooth switch over from gas to lpg even without load or naka standby lang specially pag umaga. before parang nag di-dip, parang mamatay at maramdaman mo un malakas na shake ng makina.
- idling much better compared before. medyo tahimik although i can still experience na minsan malikot siya pag matagal nkaidle.
- sudden drop non accelerator pag nag change gear ka.
- I can feel the power everytime i press the pedal. pag mga around 50kph and up prang ang tahimik at smooth.
- narrows the gap between gas and lpg in terms of performance. almost gas na siya. pero i admit smooth pa din ang gas pero kunti lang.
- fuel consumption still the same as previously. pero napansin na yun ave. km/l display sa console ko parang tumutugma na siya pag nag pakarga ako ng lpg. dame ang layo ng reading
Will be going back there before end of year kasi e fine tune pa daw kasi pinabuka lang yun injector.
Talked to Nick too if he connect pressure sensor sa kit ko para mag automatic change over to gasoline if almost empty na lpg but he told me wala daw abang na wiring sa RSI+ kit na gamit ng greenfuel. sayang.
Happy customer and lpg user here. mga ilang full tank ko lang bawi ko na yun gastos ko.
