Page 185 of 211 FirstFirst ... 85135175181182183184185186187188189195 ... LastLast
Results 3,681 to 3,700 of 4201
    May 2010
    #3681
    Typically 5 to 10 percent reduction of fuel mileage on LPG as compared to gasoline.
    This is due to LPG's slightly lower energy value per liter as well as slight inefficiency of using engines designed to use gasoline to run on LPG. A bit of adjustment/tuning can improve the LPG fuel mileage but it will compromise the way your engine will run on gasoline.
    Anyway, if you have done enough back reading, the most important way is the ignition timing. With LPG you can advance it a lot more. But if you switch to gasoline, it will cause the engine to knock.
    In my experience, the engine's stock setting is good enough.
    You might also want to check out the Sentra N16 model. My brother has one also running on Auto-LPG. It's the Sentra model Nissan Phil has been selling since 2002 until now.
    LINK: http://tsikot.yehey.com/forums/showthread.php?t=51318
    Currently I would suggest XOOM Auto-LPG (Timog in QC). It is a refilling station as well as an auto-lpg installation shop. Just mention to Nick that "ghosthunter" recommended you.
    Contact info: Nick Go
    Mobile Landline: (02)5067734
    Reason why not others?
    NAIADSS seems to have gone out of business. They used to have a station and install shop at Pioneer St in Mandaluyong but it's not there anymore (site under construction, dunno what is being built there).
    As for GREENFUEL, I have no contact with them in months. I don't know their current financial status but since their business is only in the auto-lpg installation, the "dry-spell" in between 2008 and 2010 kinda was hard on business.
    You can still try contacting GREENFUEL as their contact info in the list should still be working.
    the last time i went there (a month ago) for tune up may nagpapaconvert pa. yun nakita ko ay fortuner, ford e50 (un malaking van), yun bagong labas ng kia na pang taxi. sabi non mechanic madame daw sila nakapila pa since mahal na ulit ang gasolina. napansin ko din naglagay na ulit sila ng signboard don sa gate and don sa kanto ng street papasok sa kanila. date wala yun e
    #3682
    Quote Originally Posted by Louga View Post
    hello po, anyone experience cold start rpm issue when using lpg?
    issue: during cold start yun rpm ko will shoot to 1500 (normal) but suddenly will drop to 900 then after about 10-15secs will gradually goes up to 1300-1500 (normal warm up rpm for cold start) then will gradually goes down na (kasi umiinit na un engine). yun issue is the sudden drop to 900 kahit malamig pa engine kaya parang tunog palyado yun makina. i believe the proper warm up rpm on cold startup is shoot to 1300-1500 then gradually goes down to normal idle.
    scenario:
    1. use lpg for several days (warm up lng un gasoline) - cold start rpm issue happens.
    2. use gasoline exclusively for a day or 2 - cold start rpm goes back to normal even if you use lpg for couple of days (after the exclusive gasoline run)
    3. went to baguio and use lpg all thru out except on the "city driving" on baguio - issue never happens pag start ko the following day.
    i haven't experience/feel any unusual sa takbo ng makina both on gas and lpg. engine runs smooth. kahit patakbuhin ko siya na andon pa sa state ng mababa un rpm niya (900 but engine is still cold) ok man siya. hindi siya un namamatay or parang mamatay.
    my unit is innova 2009 sgi from greenfuel converted feb 2010 and currently runs 2200km on lpg. current odo is 22+k. yun fuel filter ko hindi pa napapalitan (i know 40k ata bago palitan ito). pinalinisan ko lang sa shell station. air filter, spark plug kakapalit pa lng non 20k pms. pinasilip ko sa kasa sabi ok man daw ecu ko. wala man daw fault na nakita.
    ano kaya issue nito? may long term effect ba ito sa engine ko or hayaan ko na lng since pag gas mode hindi siya nag occur?
    sorry masyado mahaba paliwanag. TIA
    I have a similar problem before. It was traced to a couple of defective sensors on the engine. One was the temp sensor used by the engine to detect if the engine was reached normal operating temp. The sensor would tell the ECU that the engine was warm already even if the engine was still actually cold resulting in a rough idle on cold starts.
    The sensor was functional enough not to throw a "fault" but defective enough to give the wrong info.
    May 2010
    #3683
    thanks gh. yun sensor ba dapat ereplace or linis lang? magkano kaya abutin ko sa repair? ano ba long term effect nito sa engine ko?
    #3684
    Best to have your car checked by a competent auto shop before you start replacing anything.
    If you are in the San Juan area, you can try dropping by SPEEDYFIX.
    May 2010
    #3685
    ok will do. i'm from paranaque but will visit speedyfix since wala ako masyado alam na good shop near my place. heard good feedback sa speedyfix so i'll try that. salamat ulit. atleast ngayon medyo malinaw na skin yun issue.
    #3686
    double post!
    #3687
    I inquired with Greenfuel, Manila Autogas and XOOM about installing an LPG kit on a Nissan Sentra Series 3/4 Ex-saloon. Greenfuel and Manila Autogas so far are the only ones who have replied and they both recommended the SGI kits even for a relatively aged vehicle with EFI. SGI kits are more durable, reliable and offer better performance overall.
    I'm more inclined on getting a Sentra Series 3 Ex-saloon and converting it to LPG (given that all other systems are 100%). I've been trying to search for feedback on the GA14DE with LPG, but so far no luck.
    #3688
    Quote Originally Posted by nemo View Post
    You can check the old Auto-LPG users roll-call thread:
    http://tsikot.yehey.com/forums/showt...t=51801&page=6
  9. #3689
    Good news to abandoned EROOM kit owners! Mike Tagle is the new "Mike" in Green Fuel (so he is no longer with Denso or Vogas). He has the EROOM diagnostic reader, and offers continued tuning services for EROOM kits. Check out Green Fuel's contact numbers on the LPG Installers thread.
    Green Fuel also has the Launch ECU reader/resetter, so they also offer computerized diagnostics for almost all EFI cars.
    My EROOM kit will celebrate its 3rd birthday on 5/22, and it's still tuned perfectly.
    May 2010
    #3690
    updates:
    for 2 weeks mukhang hindi na nag occur yun problem ko after ako magpalit ng plug (stock from toyota). actually nagpatune up ako sa greenfuel kasi may kunting sabit yun pagchange gear ko sa lpg tapos sabi mahina na daw plug ko so pinalitan namin. going 3500 km pa lang stock plug ko. naresolve yun lpg issue ako pero to my surprise naresolve din yun cold start problem ko.
    may bago sila technician galing econogas. nakita ko din sa mike tagle don tapos tama si *paolorenzo may obd sensor sila bluetooth. may kakabitan ata sila na fleet of 20 cars kasi may nakaline up na mga hotdog tank don.
    May 2010
    #3691
    share ko lang. nagpachange oil ako kahapon sa petron. gamit ko date shell H3 20w-50 G (yun red. pang lpg/gasoline). totoo nga na malinis pa ang oil kahit 4000km na. ang kulay ay parang same lang non kakalagay pa lang. sabi ng mekaniko ang linis pa nito . ngayon petrol ultron rallye 10w-40 semi na gamit ko since parang makupad innova ko pag 20w-50. medyo ok na acceleration niya ngayon .
    Aug 2008
    #3692
    One of the LPG owner's manual recommended to replace the LPG hoses every 20,000km. One of my mechanic friends also feels that the hoses seem a bit brittle and he has heard that these needed to be replaced at some frequency (mine is a greenfuel kit with 23K). Has anyone changed their hoses? Is this really required after 20,000km?
    Aug 2004
    #3693
    I didn't know that... I'm at 40k plus with mine... I'll check with Greenfuel...
    #3694
    I had to replace my hose from the vaporizer to the filter to the injectors. Got brittle as this was exposed to heat from my exhaust manifold and i have to disconnect this hose whenever i replace my spark plugs. This was after around 50,000 LPG kms (im at 55,000kms with my LPG kit already as of today).
    Other parts i had to change was the filter (once a year) and my vaporizer (last year at 40,000 LPG kms) as it wasnt circulating my coolant well enough and causing a backflow.
    Thought about getting silicone hoses for the parts near the hot area... is it worth it?
    Aug 2006
    #3695
    How much does it cost to replace those hoses at GreenFuel? My hose from evaporator going to injector rail looks bulging near the evaporator side and I think this needs replacement by now. Can these be retrofitted with copper tubes and just a small hose near the injector rail? The heat from the evaporator effect the lifespan of the hose.
    #3696
    GF charged me 750 pesos for the following: change o-ring 2 pcs, IN OUT the vaporizer, change both hoses IN OUT vaporizer,included na labor dito. 2 months ago ako nagpagawa sa GF. my LPG car is going 3 years na this aug 2011.. ayos na ayos basta alaga lang.
    May 2008
    #3697
    I am considering on adding a vacuum gauge for my car to monitor my driving style and possibly save fuel in the process. While thinking about this, I realized it would be better if I can also replace my LPG fuel indicator as well. I'd like to know if it would be possible to replace the fuel indicator with a gauge type? My existing LPG switch only has 4 LEDs lit up when it's full tank and would gradually disappear one at a time right after the first light goes out. I'd like to get a gauge with the graduation instead of having lights. Would this be possible? If yes, will the mechanical or electric gauge work? Thanks.
    Aug 2005
    #3698
    recently acquired a car equipped with a lpg kit. its the one that injects the lpg at the throttle body and not at the injectors. my problem is im having a back fire every now and then. sometimes if the backfire occurs the engine does not die and most of the time it dies. what do you think is the problem? any recommended shop in the south? im from cavite.
    many thanks!
    #3699
    Quote Originally Posted by gunner View Post
    many thanks!
    Backfiring might be caused by the ignition timing being too advanced.
    BTW, backfire may damage your MAF/MAP (air) sensor.
    May 2010
    #3700
    Hello - questions lang po. Pansin ko lang kasi sakin na parang delayed yun response ng kit pag nakahang yun sasakyan sa inclined (like sa indoor mall parking or fly over) tapos nakafull stop then mag arangkada sa 1st gear. Parang sa unang tapak mo sa gas parang delayed yun response. pag naka gas naman ako ok man siya e parang walang gap in between. is it normal? mine is innova m/t greenfuel sgi.
    so far ok man talaga takbo ng kit e pero ito lang yun madalas ko napapansin.
    TIA.
Auto-LPG Conversion Thread
