Hi.
Normally, the advise i read in the forums is to go one step colder. So, BP6ES would be 'the one step colder plug' in your case.
Going for BP8ES would mean 3 steps colder. Malayo from BP5ES.
Well, from what I read from either NGK or BOSCH website (cant remember which), using a spark plug of the right temp would mean better combustion.
If you are using too hot a plug, the spark plug tips, after a while, get deformed due to excessive temp.
If you are using too cold a plug, you would have carbon fouling ... so mangingitim yung mga spark plug tips after some time. The reason is that lower than ideal engine temp would result in incomplete combustion. Therefore, it will stick to your sparks. Your FC might get worse as well.
Again, based on their advise.. if you are unsure, it is better to err on the side of using a colder plug. If your sparks dont have carbon fouling after a while, then its ok. OTOH, using too hot a plug (resulting in higher than ideal engine temp) might damage your engine in the long run.
If it were me, I'd go for bp6es first. But of course if you're itching to see what happens on using bp8es, I dont see any harm in trying it. But I'd have a spare set of BP6ES plugs with all the necessary tools to change those sparks in the car all the time. Just in case....
BTW, sir Vinj did mention NGK LPG plugs, I think they should be worth trying. Even Bosch has LPG plugs.
Kiko
