Page 157 of 211 FirstFirst ... 57107147153154155156157158159160161167207 ... LastLast
Results 3,121 to 3,140 of 4201
    Aug 2007
    #3121
    Quote Originally Posted by aamd View Post
    Have you experience this kind of problem?
    SGI kit from greenfuel. Whenever the LPG automatically switch to unleaded the engine stops.
    Would you know the solution for this?
    Do i have to clean the air filter?
    I hope i can DIY if not, i need to go to greenfuel.
    Thanks...
    If the lpg runs well, it probably isnt the lpg system but rather the car's gasoline system which has a problem.
    Oh, I have this problem as well. My car is an SGI system too.
    My suspicion on my car's problem is the car's gasoline fuel pump injector. Mine seems to be an electrical problem which could have been complicated by the fact that the lpg injectors' wirings were spliced and added to the gasoline injectors electrical wirings.
    Im currently looking for someone really good in car electricals to correct this problem.
    Aug 2007
    #3122
    Hi guys,
    I refuelled at Metrooil along A.H Lacson St, one evening, switching off the engine while doing so. After the full tank, when I started the engine , sobrang naging palyado yung makina! If I let go of the gas pedal, patay yung makina! I hardly made it a home...
    the next morning, Ok na ulit siya and back to normal.
    What do you guys think? i suspect baka maraming hangin na laman yung lpg nila
    Aug 2006
    #3123
    Quote Originally Posted by webmiester View Post
    Hi guys,
    Oily LPG contamination is my wild guess. When I do experience rough idling, I usually run on Gasoline for a few minutes and then switch back to LPG. Somehow SGI injectors need to untangle its stuck up tiny pistons. On severe cases I do unplugged the LPG hose from evaporator/condenser to the injector rail and rest it for some 10 minutes and plug it back, usually rough idling goes away.
    I usually have half tank Gasoline when travelling, so I use it whenever I need to
    #3124
    Quote Originally Posted by Mile2 View Post
    Hi Mile2. I'm also experiencing this problem. Do you need to unplug all of these hoses or just hose #2? Thanks in advance.
    *Orig photo borrowed from ghosthunter's gallery.
    Aug 2006
    #3125
    Quote Originally Posted by quan2boy View Post
    Just the hose #2
    Note: Don't pull it out at once, it will make a huge puffing sound try to reduce the pressure by rotating the hose back and forth and releasing trapped LPG gas little by little.
    #3126
    Just the hose #2
    Thanks Mile2. Dapat yata meron na lang tayong valve between the hose and the injector that we can use to conveniently release trapped LPG from time to time.
    Cheers!
    #3127
    our civic vti AT is only averaging 4.5km / liter. mdyo mataas. upon checking under the hood. napansin ko mdyo maluwag un adapater kung san naka kabit un lpg hose to the engine. baka eto problema kaya? ill have it check tom...
    #3128
    oh btw, our crv gen1 AT is doing great milleage. 5 to 5.5 km / liter.
    #3129
    Quote Originally Posted by dieselNUBI View Post
    When you say adapter this is the aluminum material on top of your carburettor and where your cars air filter is placed, Did i understand you correctly? I'm assuming your vehicle is Carburettor type or EFI Type.
    You should ask your converter to install this tightly so as not to have air leaks. You should be doing at least 4.95km/ liter if your car is doing 5.5km/liter. (this is the acceptable power and consumption drop around 10% for carb and efi type)
    Jan 2008
    #3130
    for the meantime, im not using my LPG kit. Last time i go full tank on my 50L donut tank, i just reached a mix driving (60% highway), i just reached a cumulative km of 250 plus. It seems my Adventure is running so lean.
    #3131
    Quote Originally Posted by daneklog View Post
    My team won't mind taking a look at your car. See what we can do to help you with your consumption and other issues. You invested on the conversion and We'd like to help you maximize it. For as long as its EFI or Carb I think we can assist you. For SGI that would be your converters look out.
    You can visit our shop in Timog Ave. Q.C. pls. feel free to drop by we're open till saturday.
    XOOM Auto Gaz, Inc.
    Jan 2008
    #3132
    Thanks for the concern sir. My unit is an SGI. Im talking a vacation on it since im not really happy with my conversion. From time to time, may problemang lumalabas. Per my computation, very minimal na lang yung natitipid ko. Baka abutin pa ako ng 2 years for an ROI. My SGI was installed July 2008.
    #3133
    ganito din ang problema ko sa civic ko. maski na i ayos mo yung hose going to the adapter at higpitan yung clamp, lumuluwag pa din.
    im doing around 7-8km/li lpg on the average. using emulator type. kailangan nga ibalik sa installer (greenfuel) to tightly fix the hose-adapter para hinde luwag ng luwag.
    so far im still using lpg, smooth running after they replaced the busted vaporiser.also change to 1 step colder plug.
    #3134
    Ako din bakasyon muna sa LPG. The current price diff is not that significant in my case (kasi nadadaanan ko yung Caltex sa Edsa with unleaded (not E10) *P29.70/liter vs most LPG *P20/liter). Although meron pa rin konting savings sa LPG, I don't think it's worth the trouble of going back to Greenfuel every month or so for filter problems or stuck up injectors(?) or something...
    Aug 2006
    #3135
    I'm consuming 10-12 liters of LPG a day so for me savings is still appreciated. So far I'm happy with my GreenFuel conversion.
    BTW, have you guys seen the new PLDT Facelifted 2009 Innova's? It has filler port near the gas tank lid, wonder why they have to drill a hole on the body, when they can put the filler port underneath the body like what GreenFuel did to my Innova.
    #3136
    Less vulnerable to damage either by snagging something on it or vibration.
    #3137
    Kinda weird that it seems SGI systems are more problem prone than the older Venturi kits. I initially thought that the SGI systems would get around more of the problems of the venturi system. But it seems to be the other way around.
    The venturi system seems to be a more robust system if a bit crude way to inject fuel into the engine. Less susceptible to oil contamination. Only drawbacks are the lower overwall power, more frequent air filter maintenance and slightly less fuel mileage.
    #3138
    Seems to be a hot or miss thing. I guess its mainly that the SGI kits are more hooked up to the engine management system and the like; plus its still on the first stage of development over here as compared to the venturi kits which have been around longer.
    Thankfully my SGI kit is still doing well with nothing more needed then some fine-tuning in the start (same with my officemate... we both have similar rides. :D)
    #3139
    Yes this happens due to our road condition. Anyway we can fix this problem easily
    #3140
    Hi Sir
    We will gladly service your car in alabang if you need us to. We will also teach you how to clean the injectors/system
    Just coordinate with lorna
Auto-LPG Conversion Thread
