Page 119 of 211 FirstFirst ... 1969109115116117118119120121122123129169 ... LastLast
Results 2,361 to 2,380 of 4201
    Dec 2004
    #2361
    *allainroyce
    p42k nga ang SGI kit plus install sa GREENFUEL .... meron iba mas mababa lang ng konti as in p1k or p2k lower pero sa GREENFUEL na ko nagpakabit since marami dito nagpakabit sa kanila at maganda ang feedback .... yung isa tinanong ko "italian brand" p70k ang gusto para sa SGI kit hehehehe
    Dec 2004
    #2362
    okay sana p70k ang italian brand kung me logo man lang ng prancing horse sana hehehehe
    Sep 2006
    #2363
    update lng on my ride's idling issues, had it calibrated at greenfuel, it now rides like its running on petrol.im expectng an increase in fue consumption so i Need to measure it.
    Nice meeting you sir GH, ito lng masasabi ko sa u -
    #2364
    thanks ghosthunter and paolorenzo for the reply. il go na lang siguro sa greenfuel sa off ko and guys pwede kaya sa inova yun tank e dun sa lalagyan ng spare tire lalagay? kasi parang nakakatakot sa loob
    #2365
    Quote Originally Posted by ML85 View Post
    pwede yun boss sa location ng spare tire ilalagay yun tank, donut tank yun ilalagay dun...yung samen ni pao sa loob nakalagay, cylindrical tank...pao's ride is revo while mine's an adventure. ok naman, buhay pa naman ako at hindi nahihilo or nanunuyo ang lalamunan hehehehe
    __________________
    passion for fashion? craving for savings?
    visit MAI PASSION boutique at the fashion village * Tiendesitas
    #2366
    Yes this is possible. You should request for an External Donut type tank. For an Innova a 55-65 liter should suffice. The tricky part here is finding one. We recently ran out as well and will have stock sometime next month. This type of tank should also be fitted with a zero degree multivalve.
    Aug 2006
    #2367
    Sa ilalim talaga nilalagay yung Donut tank, sa puwesto ng spare tire. In this manner there's now way you can smell LPG inside your cabin, what's inside the cabin was only electricals and ECU. The spare tire can be fitted at the back of the 3rd row seats, just secure it with straps and floor stoppers.
    For Innova its the 50 liters donut tank can fit perfectly, it has the same diameter and thickness of the 205x65x15 tire. GreenFuel's donut tank comes factory fitted with multi valve already. Fuel level indicator can be adjusted by ECU programming so there's no manual floater gauge level calibration.
    BTW, there's a metallic green Innova in that compound that is always parked there and its LPG equipped.
    #2368
    For those asking how much was the refueling valve conversion (korean to italian).... it's P2,500.
    May 2004
    #2369
    Meron na ba LPG car meets? para ma compare naten mga kits naten and installation ng mga kit... para sa mga gustong mag pa install ng LPG makakita sila ng car na naka LPG... Kahit un official meet ups lang... or better buo tayo ng LPG group... hehehe... please....
    Dec 2004
    #2370
    haaayyyy mukhang malakas FC ko hu hu hu nung pagkuha ko after installation ..... i filled up 39.xx liters ... or almost 40liters ..... ngayon nakaka 92kms pa lang ako dalwa na lang ang green led ..... half tank na 92kms pa lang ??? waaaaaaaa
    Aug 2006
    #2371
    Quote Originally Posted by tediber View Post
    Naka second refill ka na ba?
    Dec 2004
    #2372
    nde pa po ..... guesstimating pa lang ako .... cylindrical tank po aken .... basta unang kuha ko ng auto nag fill up ako 40liters .... 4 na LED umiilaw .... so full nga .... after 92kms na as of today .... 2 LEDS na lang umiilaw =( .... anyway observahan ko pa siguro since nde naman ata talga accurate yang LED guage. Siguro pag 2nd fill up ko na i'll be able to calculate the real FC .
    Anyways ask ko lang ? na ca calibrate ba tong SGI ?
    #2373
    Yes the guage is an indicator only. We can calibrate the guage to actually blink early or late depending on the driver's request but we usually bring it early as auto-lpg stations are not as common as petrol stations. If you really want to get the real fc you should use up the whole tank and calculate your real driven km.
    Dec 2004
    #2374
    okay thanks for the input sir bigMIKE ..... i guess i'll wait to use up the whole tank before i can actually make a better guesstimate of the FC.
    While i was filling up kasi at around 38+ liters sabi nung nag f fill sir malapit na mag full ... kasi ata bumagal na yung meter nila .... nung 39+ na sabi ko pwede na yan baka sumabog na hehehehe.
    I'm not sure of the actual capacity of my cylindrical tank kung 40 ba or 60 ?
    Dec 2004
    #2375
  16. #2376
    I find it really difficult to compute for a reliable FC. This has been discuss previously, but LPG pumps seem to have a tendency to stop depending on its remaining contents. So kung marami pang LPG, then it can really fill your tank up to the desired full tank level (~85% of tank capacity). Pero kung konti na lang LPG sa pump, mabilis yata mag-equalize ang pressure, so nag-s-stop o no-flow na agad.
    In my last fill, nag-stop na at 40liters, tapos 3 lights lang yung switch indicator (and 2/3 lang sa tank gauge). I was expecting about 48 liters to be loaded. Mukhang konti na lang laman nung nagpa-fill ako. Nagmukhang low FC tuloy ang computation ko, but I know it's not accurate.
    Sa Petron C5/Valle Verde ako nagpapa-fill. Isa lang naman pump ng Xceed dun.
    Jun 2006
    #2377
    suggestion lang eto, try mo ubusin laman ng LPG mo hanggan mamatay ang makita, then full tank mo LPG ulit (hingi ka receipt indicating iyun liters kinargahan), tapos reset mo iyun trip meter to zero then gamitin mo hanggan maubos ng sagad hanggan sa mamamatay na makina mo... doon ka mag compute para malaman mo iyun exact fuel consumption...
    note: pag naubos na at namatay makina, switch mo ulit sa gasoline... whag kalimutan sulat mo sa receipt iyun naka register sa trip meter mo then compute mo later...
    #2378
    gud am po,
    am thinking din po of converting my car to lpg
    is it really worth the installation costs and the usual headaches (as i back-read through some pages here) that comes with modifying a petrol car to run on lpg?
    thanks po
    #2379
    Quote Originally Posted by nameless411 View Post
    gud am po,
    thanks po
    yes it's all worth it. i think 95% who enlisted themselves having their car/s converted to bi-fuel (petrol+LPG) are satisfied and are now enjoying the savings...yes, it is true that some problems occur to some, but our installers find ways to address those problems...plus we have the sensei of AutoLPG here, Ghosthunter, and the whole LPG conversion community helping each other to solve every problems regarding our LPG kit and our ride...
    ...ganbatte ne...
    __________________
    #2380
    ok. i have my city driving FC on our honda civic 96. we drove it for 175 kms. so divided it by 37liters(my full tank) = 4.7km/l . kinda high isnt it?
    my hiway FC is 5.8km/l.
    on petrol. my citry FC is 8km/l.
Auto-LPG Conversion Thread
