Page 94 of 211 FirstFirst ... 4484909192939495969798104144194 ... LastLast
Results 1,861 to 1,880 of 4201
    #1861
    Quote Originally Posted by ezem View Post
    bakit ba mahal ang doughnut tank option e less nga yung capacity nya compared sa cylindrical tank (mine has 60L tank)?
    its more difficult to manufacture a donut tank than a cylinder so it generally costs more. some installers pass on the price 100% to the customer while others would offset the price from the cylinder tank's price.
    Jun 2006
    #1862
    Quote Originally Posted by knicks1204 View Post
    hi po! i'm seriously thinking of converting to LPG because of the current gas crisis... avanza po ang kotse ko, ano po kaya ang recommended na kit? ok lang na magamit yung pinaka "trunk space" ko kasi lagi nakababa yung 3rd row & may subwoofer po sa likod.. TIA! :D
    Avanza needs SGI kit. Plastic intake manifold kaya di recommended ang mixer type kits.
    Kung malapit ka sa Quezon Ave, go to Toyota QA. May display sila na converted J model. Mas mahal pag sa Toyota ang conversion. You can check GH's list of conversion shops.
    #1863
    Quote Originally Posted by kapitan88 View Post
    sa mga nakapag convert na, are there special maintenance na ginawa nyo since conversion?
    In my case, I only have increased the cleaning/replacement schedule for my engine's air filter. Other than that, everything is normal as if I was running on gasoline.
    Some users say that, mas magiging mainit daw ang temp by using LPG, so may remedy ba dito?
    some users... I assume those would be taxi drivers? Anyway, you will potentially experience engine overheat if your auto-lpg system (as with a gasoline system) is tuned to run on a leaner air-fuel ratio than recommended.
    To counter this, have your fuel system tuned to run on the correct air-fuel ratio.
    1 installer said na once converted to LPG, kailangan fully synthetic oil na ang gagamitin sa engine. what other maintenance ang kailangan mo gawin ngayon dahil converted ka na, unlike before.
    I am running on regular motor with regular sparkplugs running on a typical tune-up schedule for the last two years. No need for synthetic motor oils nor special spark plugs. Taxi cabs (lpg or gasoline or diesel fueled) tend to require better oil because of their operating environment (250 or more kilometers in a day).
    Na mention din nung installer na kailangan daw in top condition ang engine, otherwise mas magiging disadvantage ang kit, especially yung may mga oil leaks o singaw somewhere. any comments sa mga naka convert na.
    Auto-LPG is just like running on gasoline. Any existing problems will NOT be cured by converting to auto-LPG. So if your engine has a tendency to overheat with gasoline, it will still have the overheating problem when running on LPG. The same with oil-leaks, it will NOT magically disappear if you switch to running on LPG.
    A poorly maintained engine will perform poorly whether its running on gasoline or LPG.
    #1864
    Sad naman.
    Am interested sana to convert my 07 Mazda 3 to lpg, i called the dealer (GH) ma void daw warranty if ipa convert.
    #1865
    sa mga nakapag convert na, are there special maintenance na ginawa nyo since conversion? Some users say that, mas magiging mainit daw ang temp by using LPG, so may remedy ba dito? ! installer said na one converted to LPG, kailangan fully synthetic oil na ang gagamitin sa engine. what other maintenance ang kailangan mo gawin ngayon dahil converted ka na, unlike before. Na mention din nung installer na kailangan daw in top condition ang engine, otherwise mas magiging disadvantage ang kit, especially yung may mga oil leaks o singaw somewhere. any comments sa mga naka convert na.
    ang alam ko lang na special maintenance na ginawa ko since nagpakabit ako ng LPG kit is yung cleaning the air filter more often, other than that wala na yata. as for the engine oil, i think minerale oil works just as fine as the synthetic oil. as for the temp, alam ko yung issue na overheat sa mga taxi is yung 1st gen LPG kit e, si sir GH ang makakasagot ng tanong na yan. about the engine condition, whether your ride has LPG kit or not, i think the engine should always be in a top shape.
    #1866
    Quote Originally Posted by a4Tech View Post
    Sad naman.
    well, it's still your choice and computed risk if converting to LPG is worth it. Just compute how much you can save in a month.
    #1867
    Sad naman.
    i suggests na hintayin mo muna matapos yung warranty (3yrs or 50k kms, whichever comes first, right?) before ka mag convert sa LPG. sayang kasi yung warranty, engine warranty ang mabo-viod pag nagkataon e.
    #1868
    Kung hindi naman taghirap at naghahanap ka lang ng paraan to save more money then wait ka na lang matapos warranty. Pero kung taghirap na, to hell with the warranty
    #1869
    this is the part i cannot comprehend. . .i wonder why some won't offset the cost of the cylinder tank, completely unused naman yun
    #1870
    Quote Originally Posted by vito corleone View Post
    I am just basing it on the price of the tank (cylinder to donut) option. I was able to canvass the price of donut tanks at some manufacturers abroad as well.
    Some auto-lpg companies charge P2K for the donut tank option while others would charge you P7K. Go figure.
    #1871
    oo nga, boss gh. . .i'm just wondering. . .the question is directed, actually, to the installers. . .maybe big mike can provide a little light into it. . .i never see him post lately, though
  12. #1872
    Tingin ko with EROOM, they probably by the kits by the set. So whether they use the cylindrical tank or not, it's probably the same price for them. Dapat yung EROOM/Koreans ang mag-adjust, so Denso can give better upgrade options to customers. I'm sure marami na rin customers who turned to other installers because of this. Sayang, kasi I think the EROOM system is really good. Laki lang talaga nung tank na naka-bundle.
    #1873
    i think may nasabi dati si mike (bigfootoz) dito sa forum na they also offer torpedo tank in which (i think) mas maliit compared sa 66L cylindrical tank nila though i never had the opportunity to see those torpedo tanks dahil nung nagpa install ako, ang available is 66L cylindrical tank and the donut. ok sana yung donut though di kaya kasi ng budget hehe last time na nagpunta ako sa EROOM/ Denso-Coolmate, may 3 cars ang nagpapa install ng LPG kit, a 99 cefiro, a Volvo SUV, and 2002 honda city, and may nag inquire pa na naka BMW 5 series amp
    * paolorenzo
    bro may pic ka ba jan ng setup ng likod ng revo mo, the "tank in the box" hehehe post mo naman
    #1874
    Wait and see pa din ako.
    I'm setting my fuel tolerance up to 65/Liter. Pag lumampas dun..to hell with warranty.
    #1875
    "big mike" has been busy lately. A lot of people having their rides converted to auto-lpg because of the current fuel prices.
    #1876
    then it's just a matter of time . . .start canvassing and decide which system to install
  17. #1877
    Meron sila nung smaller tank, pero same diameter as the 66L tank, half the length lang. Hindi ni-recommend ni Mike, kasi nga 6mm yung tubing nung smaller tank, and the 6mm copper tubing is nowhere near the quality of the 8mm standard tubing. That's why di ko na pinilit.
    * paolorenzo
    Eto sir:
    More pictures here - http://s144.photobucket.com/albums/r...vo%20Auto-LPG/
    Jun 2008
    #1878
    We have the same situation, pero decided na ako, don't care about the warranty anymore. I'm just waiting for the installers to open their credit line....Stargas said baka next month puede na. I bet the other installers will also be doing the same.
    #1879
    * paolorenzo
    nicely done...camouflaging it as a woofer box...wag lang talaga titignan yung front ng grill...though at first kala ko may 12" sub talaga...nakita ko lang sa photobucket mo yung front view e hehehe
    #1880
    sorry double post..
Auto-LPG Conversion Thread
