Quote Originally Posted by paolorenzo View Post
Ok yung EROOM kit. Tuning is computerized, actually may device sila na kinakabit sa LPG ECU to measure and change the parameters. Ok rin yung auto-switch, pero minsan matagal mag-switch to LPG (parang over 2 minutes yata). Obserbahan ko pa. Overall happy ako, lalo after ko magbayad ng 1.3k lang para sa full-tank (sa Total, 45 liters).
congrats.. please post a more detailed feedback whenever possible..
The only major drag with my open loop system is the more frequent air filter servicing intervals.
when you say servicing, linis lang ba or replace na? and how frequent?
Basically the same din sa GREENFUEL. They connect a laptop to the system's ECU to see the current system parameters and sensor signals. They can also change parameters or use the self-learning system to auto-tune the LPG system. After everything is set, the new settings are saved to the LPG's ECU.
do they also apply this computerized tuning to open-loop system?
my mind is really set on converting.. the only thing that's holding me back is the lack of refueling stations outside manila, particularly in nueva ecija.
