Results 1 to 20 of 4201
    Jan 2008
    Quote Originally Posted by jedi View Post
    Please report all AD related post to us... we will delete the post and warn the member.
    again tsikot forums is not a public marketplace...
    Agents/employees of greenautogas.... please follow the rules.
    sir jedi does this include PM's?
    auto-LPG price now at P27.80/L
    (previously at P26.80)
    vs
    unleaded gasoline at P49.07/L
    Sep 2006
    update ko lang po dun sa maingay ko na car. di po pala galing sa lpg yung ingay kundi sa brake pads na naupod. nagkataon na bigla siyang nasira after the installation ng lpg kit ko sa car ko. tama yung sinabi ng installer ng lpg kits ko na minsan yung lpg kits ang nasisisi pag meron nakikitang deperensya sa kotse. however, what i really notice is that every morning hirap magstart ng kotse. 3 times na akong nagpatulak this week para lang sya umandar. dati naman 1 click lang sya. any work around on this? ayoko pa bumili ng bagong battery since im not sure if this would really help.
    Aug 2007
    Quote Originally Posted by rorymabangis View Post
    I recommend to start on gasoline mode. If it still has difficulty starting in gasoline mode, its probably not your lpg system at fault.
    On my SGI system, it starts the engine on gasoline mode by default, then changes to lpg kapag mainit na makina. The lpg installer explained to me that the lpg doesnt get burned that well when the engine is cold.
    I read in an Indian car thread that this method will also help prevent your gasoline system from running dry, so your gasoline line remains reliable.
    I guess you have the mixer type kit.
    Switching over to gasoline mode for starting your engine when it's cold. After its running a few seconds, you can switch over to LPG mode (a slight rev up of the RPM will prevent the engine from stalling during switch over).
Auto-LPG Conversion Thread
