Quote Originally Posted by jinrai View Post
hi ms. sharon,
can you also make recommedations for a 95 galant vr v6? TIA
which lpg kit do you think would work best for my car?
I'm not sharon but...
Your engine will probably run well with any type of LPG kit since the intake manifold is cast iron (well, I think so but correct me if I am wrong here). That means you can have either the open or closed loop mixer type LPG kits installed for around P22K to P25K depending on who installs it and which kit you will prefer.
You can also choose SGI-LPG kits but it would still cost you P39K to P40K depending on if you choose GREENFUEL (Mike) or GREENAUTOGAS (Sharon). Advantage of SGI kits is they tend to best retain the power and performance of the engine before & after LPG conversion.
Note: although mixer type kits tend to loose some power, it is possible to tune the mixer type LPG kit to minimize the power loses to about 5% at the higher parts of the RPM range.
