Results 21 to 29 of 29
- Apr 2008
- 4
April 7th, 2008 07:23 PM #21Waste vegetable oil can be cleaned and semi-processed before its used on a two-tank system. In the Philippines, there is a a manufacturer, installer and I've been using it in 3 of my commercial trucks for 2 years. The gumming issue can be remedied. One truck has been using it for 23,000kms.
We buy the used veg oil from them too.
May 5th, 2008 04:33 PM #22
how much is a two tank processing system and how much WVO can it handle per hour or per day?
- Aug 2005
- 121
- Apr 2008
- 4
May 11th, 2008 03:14 AM #24The two-tank kit is installed in the vehicle. It does not clean the waste vegetable oil. There is a separate filtration system that processes the wvo so it can be stored and transferred clean to the vehicle when needed.
Vehicle conversion = P25k to P45k (big trucks)
WVO Filtration System = P45k
Savings is about P10 per liter compared to diesel pump price. And thousands of pesos in savings against fines and kotongeros during Smoke Belching operation. Makes lot of sense for those who consume lots of diesel like commercial vehicles, jeepneys etc. WVO is substitute for diesel not gas.
May 11th, 2008 05:28 AM #25
Even if the ambient temperature back there is in the high 30's, it is still highly recommended to pre-heat the WVO fuel lines in order to ensure the fuel is thin enough and will be easier on the injection pump. This ensures longer life of the engine as well as the injection pump. It doesn't have to be a fabricated heating element but just route the fuel lines near a radiator hose or close to a hot spot in the engine.
Please do a search on "Lovecraft" and its issues with killing lots of nice MB diesels because they previously used a single tank system without any form of heating. I understand here in the US it's a bit colder, but I think if the main goal is to save money in the long term use then preventive maintenance must be done to properly "thin" the fuel so it won't cause engine or IP failure in the long term.
Just be really careful in using these for common rail injection systems, since those are more expensive than the older engines with purely mechanical injection systems.
- Apr 2008
- 4
July 17th, 2008 03:02 AM #26Make a search for Biodrive Philippines. There are interesting answers in that website.
July 17th, 2008 08:27 AM #27
nice site but still lacks a bit of development like pictures of the actual products being sold.
July 17th, 2008 08:29 AM #28
July 17th, 2008 11:48 AM #29
WVO is gaining popularity here in iloilo. A local transport company is using a 30/70 mix of diesel and WVO. The WVO oil is filtered with crude backyard device, fabricated locally. Still, it does the job, and the stench of the exhaust is somewhat pleasing. Its smells more like fried food than the usual obnoxious fumes of diesel or any vehicle for that matter.
IMO this approach is safer compared to going straight WVO. You still enjoy huge savings on fuel.
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
