Results 121 to 130 of 224
May 8th, 2014 02:29 AM #121
The Hard Starting issue is a thing of the past....the mirage has been int the market well over a year now....MMPC gave the mirage a 5yr warranty.....and most owners that had this issue had them replaced and fixed under warranty with no extra charges....
BTW...we also own a wigo and we were the first batch released since its launching.....we also experienced the hard starting issue as well..go figure! :D
case in point.... as you can see in the numbers game based on the sales of this nifty ride(mirage)...there becoming more like the beos...theyre everywhere! :D
- May 2014
- 90
May 8th, 2014 06:41 PM #122
- May 2011
- 114
May 11th, 2014 05:45 PM #124GLS CVT mirage owner here. Never had a hard-start issue.
Sent from my iPad using Tsikot Forums
May 11th, 2014 11:26 PM #125
If a problem keeps on recurring on a specific vehicle and not to majority of other units then the design flaw COULD be the driver or rather bad driving habit. Otherwise, every vehicle should have the same problem if it's a mechanical design flaw. A good example would be the Montero Sport SUA driver design flaw.
May 12th, 2014 07:54 AM #126
AFAIK as a lurker of the mirage group only one has encountered the recurrence but not that long (less than a month i think) but after it was (nee drive plate) adjusted everything is fine. two of my friends who owns a mirage says they havent encountered such issue. both are GLS AT, a 2013 and 2014 models. a neighbor also has a wigo bought 2 months ago. he said city driving is ok but not for provincial trips wherein you need to put some loads.
May 12th, 2014 10:49 AM #127
It was really an issue with an early batch, due to a defect in the supply from a subcontractor. No other Mirages were affected.
Besides... if you're buying a small car for economy or low running costs... you never get an automatic.
- 53,434
May 13th, 2014 12:56 AM #128
- Dec 2008
- 16
May 24th, 2014 10:34 AM #129based sa observation ko.
wigo is more larger looking in the inside and outside. pag my dumadaan na mirage, naliliitan ako sa itsura.
wigo is more like a jazz.
May 29th, 2014 07:52 AM #130
Paps naka auto shut off ba yung headlight ng wigo kapag naiwan mo naka bukas?
wigo versus g4
