Results 21 to 24 of 24
- Jan 2007
- 2,234
May 31st, 2008 03:30 AM #21Thanks for the heads-up, but I'd still vote for something else. Most likely the new Strada, which looks good, rides good and has the best safety rating among the current crop of small pickups.
In the original test the Navara scored very low because of bad airbag deployment and frame intrusion. It looks like the software update helped fix the airbag deployment problem, but the fact remains if you crash the Navara there will be significant deformation and intrusion into the passenger cell.
From your own link:
However, the passenger compartment was again unstable which, combined with the chest compression measured by the dummy, led to protection of the driver's chest being rated as weak. Structures in the dashboard presented a risk of injury to the knees and femurs of both the driver and passenger. There was extensive deformation of the driver's footwell and the car was penalised because the lower chassis rail punched a hole in the toeboard. Dummy readings indicated weak protection of the driver 's lower legs and rearward movement of the pedals led to protection of the feet and ankles being rated as poor.
- Jan 2007
- 2,234
May 31st, 2008 03:47 AM #22
May 31st, 2008 11:35 PM #24
This is why I love EuroNCAP testing results, because they evaluate and analyze structural deformation.
Given that many crashes you see on the road fail to deploy airbags because they don't meet airbag opening criteria (offset too high, impact is with a pole, etcetera), it's even more important to take into consideration structural deformation in a crash.
Airbags are a supplementary system. In other words, airbags help minimize injuries, but if the structure of the vehicle cannot withstand impact, they won't do crap.
The Strada, so far, is the only truck amongst those tested in the EuroNCAP to actually score decently with little body deformation compared to the other trucks tested.
No tests yet for the Hilux, though.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
