Page 40 of 57 FirstFirst ... 3036373839404142434450 ... LastLast
Results 391 to 400 of 570
    #391
    kung 4x4 capabilities/functionalities ang paguusapan dun ako sa Fortuner pangalawa un MS.
    #392
    :1stplace::2ndplace::3rdplace::clap: makabili nga ng March Issue
    yabang ...
    makabili nga rin,
    #393
    Quote Originally Posted by doc vince View Post
    I dont know about that bro, but if there was no changes in the suspension compared to the old model & the only change was type of wheel diameter for the mags & new set of tires, then probably its the new kind of tires that gave some improvement on the ride of the facelifted model. But if your claiming that the ride did not change one bit when you shifted to 20 inch rims and low profile tires, then you must be kidding yourself., no pun intended. A lot of fort owners upgraded their suspension & spring to TEIN to improve the ride especially if you modified the rims to 20 inches. Mas naging matagtag kasi pagnagupgrade ka sa bigger rims & lower profile tires.
    my post here is not from hearsay or from someone write in the forum and read by someone...it's from the guys i know very well who actually drive my fort oftenly. they compare the stock mags and tires to the new one and unanimously they favor to the new one, they find it quiter,smoother and it makes the steering wheel lighter...my new tire has diff tread pattern ( non directional and high performance radial)compare to stock,the design is bias more for comfort and quitness...
    Jan 2008
    #394
    Quote Originally Posted by saipeme View Post
    Sir saipeme * any vehicle US, european or japanese brand when you change the tires to a bigger one with a low profile tires the riding comfort of your ride will be suffer specially you mentioned that you didnt change your shock... but i agree to you that the wider tires you have right now will be advantage on the handling and breaking of your vehcile also more smoother or less noise.. but again not the riding comfort with fort..
    #395
    Quote Originally Posted by s_quilicot View Post
    yabang ...
    makabili nga rin,
    :shhh: nothing against the other 2 actually kasama sila sa choices ko before kaw talaga oh :cheers2:
    May 2008
    #396
    Quote Originally Posted by trevvs View Post
    C! and topgear (though the final statement is fortuner) have said otherwise right?
    Aug 2008
    #397
    Quote Originally Posted by alainroyce View Post
    i second this sir saipeme, that is the logic behind it, the higher the profile of the tire and the smaller the rim, the more the ride improves (comfort from potholes while driving on it), but the looks & sportiness factor decreases. On the other hand, the lower the profile of the tire and the larger the rim diameter gets, the ride worsens, but the looks and sportiness factor plus handling will definitely be on the positive note. So again sir saipeme, that would be impossible if increasing your rims to 20 plus lowering the profile of your tire will improve your forts ride, no pun intended. Dont be confused with the comfort of the ride with the easeness of maneuvering your vehicle (handling performance).
    Jan 2008
    #398
    Quote Originally Posted by pup2 View Post
    Buti hindi si Yuichi ang kasabay mo sir. hehehe. Anyway, I did the math and found out that the power-to-weight figures for all 3 vehicle types are not all that different:
    MMS SE = 77.43 bhp/ton Tor=335
    SF CRDi = 78.53 bhp/ton Tor=343
    Fort 3.0V = 83.8/ton Tor=343
    Torque Figures aren't all that different either so short or long run, halos pare parehas ng potential. I conclude therefore that Yuichi was right and that you were merely not in the optimum power band/rpm.
    I considered bhp more kasi as you can see, halos pare parehas ang torque figures ninyo. And while torque is good for climbs and acceleration, at the speed you were going at, basically yung 'peak' ng horsepower ang hinahanap ninyo. In other words, though they may have seemed to pass you with "ease," they were probably revving higher than you.
    The good news though is that kung binagalan niyo pa ng konti, you probably would've hit the peak of your fuel-economy band.
    agree...
    baka mabagal lang talaga magpatakbo kaya nauunahan..
    nasa 2000rpm lang kasi yung SF kaya nauunahan ng iba which surely revving at 2,500 to 3000 rpm..
    #399
    you may perhaps right on that logic, again its my friends and my driver actual obsevation the claims could be wrong... from other forum who did notice of improvement using the same tire...
    http://pinoyfortuner.14.forumer.com/...pic.php?t=2750
    to me tire profile of 265/50/R20 has still enough room (132.5mm of sidewall) for giving decent ride it is relatively the same oem sidewall to most compact car...
    #400
    But a compact car doesn't weight as much as your SUV. By going to a shorter sidewall you have less flex of the sidewall itself and in order to do the tire needs a stiffer sidewall. With the higher sidewall there is more flex of the wall and it can also absorb some of the shock when the tires hit a bump or pothole. There is a reason why off-roaders use tires with bigger sidewall, it allows them to deflate tires without the risk of losing the bead so that they can get better traction in off road conditions, and when the tires are inflated in absorbs some of the shock from the bumps off road.
New Montero Sport 4x4, Fortuner 3.0 4x4 or Sta. Fe 4x4.
