I own a 97 vanette. I did not change the radiator and did not add an auxilary fan on my van. All i did is change the position of the condencer and overhauled the radiator and used
purified water in my radiator. Hindi na nag ooverheat ang vanette ko. Hindi na kailangan magpalit ng radiator at magdagdag ng fan.
Most car owners i know use tap water in the radiator... this is wrong because rust will surely accumulate!
Never poor tap water on any kind of radiator on any kind of car! Wag gumamit ng tubig galing sa gripo, kakalawangin ang radiator at water pump. Any radiator using tap water will surely overheat. If you happen to stop over by a gasoline station and let the gasoline boy check your radiator, dont let him poor tap water in your radiator. It is worth buying a purified water or any kind of drinking water for your radiator. Magsisisi ka sa huli kung tap water ang ilalagay mo. Walang katapusan na kalawang kung tap water. Kahit dagdag lang ng tap water sa radiator bawal talaga. The best thing to do is overhaul the radiator first and put only purified water or yung mga ibang bottled drinking water na nabibili. Kahit sa water reservoir ng raditor lagyan din. Tip lang sa mga tsikoteers.
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
